thewraith2008
- Joined
- Nov 22, 2016
- Messages
- 1,857
Testing a different UI approach for the new plug-in that TSSDR created.
Just posting to see what people think off it.
In the (wide) image below, you can see the changes added:
TetraNetMonitor is in very early development and still has issues with decoding, i.e. lost PDUs and speech (stutter) as well as tuner selection, this can get quite fustrating at times as it can move away from your set frequencies. I have an idea about the last issue, it's just figuring out how to implement it.
- Highlighting for active call in the 'Calls' tab.
- Highlighting for the set frequencies to monitor in SDR# spectrum view. (Same as AUXVFO)
- Minimized SDR# side panel footprint. The default layout just takes up to much room and is difficult to see all of them when there are a few tuners added to SDR#.
- Satellite tuner windows which replaces SDR# side panel. Also has larger timelsot indicators.
- Added main carrier column (mCarrier) to 'Calls' tab. This helps show what main carrier a call on a carrier belongs too.
