Tytera TYT UV MD 380 Radio Help
Hey Everyone!
I have a small firearms business and I have a couple of radio channels that I got from the FCC. I am by no means a professional so I am sure something is programed wrong, but my radios are constantly having static on every channel. I have linked a video below, any tips or tricks to try to fix it are appreciated.
KevinC
Other
Super Moderator
Home
Give us your callsign and maybe someone can check to see if your frequencies are used by someone else in your area.
KevinC
Other
Super Moderator
Home
I "assumed" your member name is your company name and found your license. Does this happen on both the 462 and 467 frequencies?
You may want to post your programming file for us to take a look at.
alcahuete
Antelope Acres, California
Are you using DCS or CTCSS? It almost sounds like something locally is potentially interfering, not someone else on the frequency or nearby, but it's really hard to tell from the video.
737mech
Clark County, NV.
I would suggest take a drive and get away from that area to determine if something nearby is the problem. Also check if you programmed those channels as digital not analog? Can you post a screen shot of one of the channels on CPS?
Ubbe
Stockholm, Sweden
They come in box with both a VHF and a UHF antenna. Probably easier logistics doing that. You seem to have the VHF antenna on the radios.
It probably doesn't matter to the interference. You get the same interference having only one radio powered on? It's the kind of interference that you get from other electronics CPU's in operation. Open squelch and try and find where the signal are the strongest, perhaps using your finger as an antenna, or holding your hand around the antenna to reduce the signal and then hunt around to find the source.
/Ubbe
kd1sq
Caswell, Maine
Hi Viri.
You said "newbie" that's okay, so let's start right at the beginning. First of all, you stated " static on every channel " - so, are you familiar with a radio's squelch function and have you made sure it's set properly on those two radios? If you leave the squelch turned too low that will give you static on all channels, all the time.
