Tytera (& clones) and "Admit Creteria"
i2NDT
Dalmine, Italia
it seems to me that the Admit Criteria "Color Code" does not perform as espected and let me transmit even if the TS I am "tuned" is in use by another TG on the same repeater and with the same color code...
did someone else verify this???
best 73
de
i2NDT Claudio
jonwienke
More Info Coming Soon!
VA
Color Code admit criteria doesn't work properly; it is the same as no restriction. The issue still exists in the most recent TYT firmware, at least on simplex.
N4GIX
Hot Springs, AR
Mine seems to work properly. If the time slot is already in use, I get "Bonked" and refused connection...
jonwienke
VA
On a repeater? What about simplex?
What firmware are you running?
Factory firmware S013.032 never refuses connection with Color Code admit criteria on simplex. I just tested to verify.
N4GIX
Hot Springs, AR
I'm running under firmware version: D003.020
