Uniden GPS Kit mounting question
RadioBoston
Boston, MA
I would like to know if the GPS Module works if it is not attached to the windshield?
Basically, my question is would it work if you leave it in the cup holder, or glove box.
Thank you.
Hit_Factor
Saint Joseph, MI
It might, it might not. The tall buildings in Boston may affect reception as well.
Does the GPS on your phone receive while in the cup holder/glovebox?
For location based scanning, a continuous signal isn't really necessary. As long as it gets a fix every now and then it should be OK.
cognetic
Indianapolis
My personal favorite location is behind the A-pillar cover with magmount/3M tape. Careful attention to avoid interference with airbag deployment - there is usually an ideal spot at the base of the A-pillar beneath the airbag mount. This gives a good sky-view above the dash. Easy to route cable behind, below dash in a concealed manner to center-console.
- cognetic
tweiss3
Is it time for Coffee?
Ohio
My CB-GPSK for the SDS-200 has no issues sticky taped to the overhead compartment right next to the scanner.
