UniTrunker 13 w/P25, no luck
DaveH
Ottawa, Ont.
Trying to get UniTrunker 13 working with a P25 system with no luck. Strong
CC, using W98 w/SB16 sound card (line input). UniScope is showing activity but
I'm not sure what settings should be or what to look for. UniTrunker shows
"no input signal" and adjusting input level doesn't make it work. Tried all
manner of options, nothing works.
Decoding is fine with 3.6k Moto systems and EDACS. Ideas/suggestions?
Dave
mancow
N.E. Kansas
It's working with a P-25 system here under Vista using a Toshiba laptop. There seems to be no rhime or reason. Just keep fine tuning the mic input controls a little bit at a time. If it doesn't work try a different computer if you can.
DaveH
Ottawa, Ont.
Rick,
Sorry I didn't get back to you on this sooner. UniScope was showing
a clipped waveform regardless of the level setting (tried mic. and line
inputs). Then I was going to try on a different computer, an old P2-500
with no soundcard, so found a cheap Yamaha board and tried to install
on Win98SE; no luck. Then the HD got hosed, so I got a new one, and
picked up WinXP home, now installed. Now maybe I can try it again...
So, am I likely to have problems with non-SB soundcards?
Dave
