Updating Sites in PPS
jpb
I changed my STARS FSS to 625 KHz and finally got a lock. Not sure how long it took to get it, but it was probably more than 30 minutes to cover 151.000 to 162.000 MHz. Perhaps the internal G5 VHF antenna is a contributing factor to reception.
jpb
@RaleighGuy, you got the answer much sooner than I did, but here are the benefits of today's homework: For STARS and Full Spectrum Scan, I had originally started at 151.000-162.000, which encompassed the range of all STARS VHF frequencies. I needed to use 6250 Hz steps. With the help of Excel, I found by starting at the exact frequency 151.0325 and ending at 161.950, I could step at 12500 Hz steps and not miss any of the control channels. I locked onto a control channel in 12 seconds. Reception is definitely the challenge for the G5 in VHF.
@RaleighGuy, you got the answer much sooner than I did, I found by starting at the exact frequency 151.0325 and ending at 161.950, I could step at 12500 Hz steps and not miss any of the control channels. I locked onto a control channel in 12 seconds.
Wow, I wonder what was recommend in post 19 for you to use.
