USCG "Private" Federal AIS Frequencies?
WirelessMike
I have recently seen USCG cutters with my eyes, but they do not show up an AIS websites, in areas where I know there is very good AIS coverage.
It got me thinking that the USCG still wants to know where their boats are, and USCG helos have to also find USCG boats. I am sure there is a sat based "report position to USCG HQ" system, but I also thought that it would be VERY cheap and easy to just transmit AIS on a "private" frequency in the VHF or UHF federal bands.
Has anyone heard of this or how the USCG reports positions internally? Any frequencies I should try?
TIA
When has the government ever chosen "cheap and easy", though sat links now a days are inexpensive way of tracking. Even if there were VHF or UHF channels used they'd almost certainly be encrypted and you wouldn't hear anything.
That said, here is a great resource for USCG freqs;
They just shut off the transmit position function. They can listen, but they won't show up on AIS.
Well, it wouldn't be private. Someone with a scanner/SDR would find it, figure it out, and stream it to the internet.
Not sure how they do it now, but we used to have what was essentially an HF packet system that could send data encrypted over HF channels. That was a l-o-n-g time ago. Probably using satellite now.
Any of the cutters/boats/aircraft have encrypted VHF/UHF capability. Most of them also have encrypted HF.
They also have the IFF systems that are encrypted.
dlwtrunked
TIA
I have often heard USCG pass position reports on their 160 MHz area frequencies.
I think your conjecture about a sat based system is unfounded and I know they have no private AIS frequency. They do transmit on the two regular AIS frequencies.
trentbob
W3BUX- Bucks County, PA
Along the Delaware River from Trenton through Philadelphia and points South sector Delaware Bay uses CG 121 and CG 409. On things like routine buoy maintenance both sides are in the clear and sound like routine Coast Guard communication. Loud and Crystal Clear.
Sometimes I can hear one side of the conversation, other times I'm sure I can't hear either side such as in drug interdiction and so forth, as it is encrypted, sector Delaware Bay also covers the Eastern coastline along the New Jersey Shoreline and use additional p25 conventional digital frequencies.
RFI-EMI-GUY
Didn't some satellites get fitted with AIS receivers to cover the oceans??
RFI-EMI-GUY
Are you confusing the distress 406 MHz frequencies?
AIS uses 161.975 and 162.025 MHz.
Nope. I am pretty sure that AIS was installed on satellites. seems like everyone is in on the game. Not sure how mature this is or who operates it. It is receive only so the revenue stream is going to be from whoever aggregates this data.
northstarfire0693
North Carolina
The aircraft are using HF quite a bit. I was shocked they still use it over satcom, my understanding is only one air station uses satcom, and of course VHF/UHF. Can run encryption on all. They also have the ability to use P25 conv and trunk on all three bands. IFF systems are encrypted.
WirelessMike
My comment about private was with PRIVATE in quotes - thus "Private" frequencies. Obviously, no frequency is private, but using a non-standard AIS frequency would keep it off the internet (for a while) , but would permit various USCG units to see each other whereabouts.
I am very familiar with IFF and other encrypted systems, but IFF is much more tactical and heavily used by aircraft and tactical coordination (such as aerial refueling). IFF also does not integrate well into small boats chart displays.
I was theorizing, that a simple system for smaller patrol boats coordinating with larger cutters, using an AIS type system, that displays on the various chart display, would be VERY handy, and easy to implement. it could even be encrypted, if warranted.
As I have said, I have seen USCG small patrol boats and cutters with my eyes, but not show up on AIS radios (nor the web) so they obviously chose to turn off the standard AIS transmitter (for certain missions), but I can not help think that they still want the ability to "see each other" when several boats are patrolling the same area.
My thoughts are that the small patrol boats want something simple and cheap, and not the sophisticated systems that a cutter would require.
I still think that COTS satellite / geolocate systems would integrate into a small patrol boat nav system well.
Or another way to phrase the question: - If I see a USCG small patrol boat with my eyes zipping around a harbor at 20 knots, and it does not show up on on AIS, what do you think they are using? I doubt IFF on a small 2 to 4 person boat. I doubt they were running RF silent for geolocate data transmissions. USCG District HQ and coordinating cutters nearby would want to know where they are located. I suspect voice position reported would NOT be adequate, if the mission is important enough to turn off the standard AIS TX.
Thanks for the insights and thoughts on the matter.
Well, here's my take on it,
"private" isn't the term they'd use. They'd use "secure". Simply running on a different frequency wouldn't qualify as 'secure' in USCG terms. It's only useful until someone figures out what they are doing and then uses available software and an SDR to get their location. Then it's not longer secure, or private. Kind of like hiding the key for your front door under the mat.
Radar would meet that need.
It's been a long time since I did this stuff, and back then AIS wasn't a thing. Heck, GPS was 'new' to us. We still used LORAN-C as our primary navigation means.
The few times we sent a small boat out over the horizon, they carried a VHF radio and a hand held LORAN-C receiver. On the bridge, they kept track on the radar.
I'm sure a private secure AIS type system would be great, and I don't know for sure that they do not have such a thing. Just never heard of it, but there's a lot of stuff I probably haven't heard of.
Well, they have radar and lots of communications tools. Maybe they have such a thing, maybe they don't. If they do, it's going to be secure. They have encryption on their radios and if they are going to shut off their standard AIS system to do sneaky stuff, they'd be smart enough to encrypt whatever secret AIS system they were running.
I don't know. What I do think is that you are confusing the roles of the boats you see in the harbor. The small boat stations primary role is search and rescue. Usually at least one person on the crew of that boat has been through the appropriate boarding team schools and they have law enforcement authority. But their job is not to chase down drug runners. The USCG has specific teams and assets for that. Those specific assets have different capabilities than what you'd see running around the harbor. The aircraft have satellite capability, as do the larger ships. The smaller boats used by the maritime law enforcement teams probably have similar stuff. The satellite antennas used is very distinctive, and I've never seen one on top of the standard RBM's and similar boats used at the station level.
So, different roles. Shutting off the AIS is an easy solution. While you might think they are running "blind" with it off, they usually aren't. District level HQ wouldn't be live tracking individual small boats like that. That would be handled at the station level, and checking in periodically by voice would be sufficient.
If they do have some secret squirrel AIS system, I'd be a dollar its encrypted. Sort of pointless without that.
If you find something different, let us know.
MUTNAV
My 2 cents.... I don't even know if this is possible, but could a marine VHF radio that is set to transmit DSC location data (ch 70) on a routine basis do the equivalent of AIS, that suits USCG purposes?.
Joel
DSC can include GPS location data.
But, again, not secure.
Easier way to do all this would be sending GPS location data over their existing encrypted VHF or UHF radios. No idea if they do that or not. P25 supports it. Interfacing a GPS to the radio is easy. Most modern P25 capable radios have GPS receivers already built in.
"Security by obscurity" isn't really secure, it's just hiding. Eventually someone finds it. If USCG was doing some sort of unencrypted location pings, I'd bet someone would have found it by now. According to this very website, there's quite a few people out there with scanners/SDR's just looking for unknown frequencies to figure out.
crazyboy
NJ
Look up STEDS (Sensitive but Unclassified Tactical Information Exchange and Display System) and older Blue Force which allows encrypted AIS over the VHF AIS frequencies. The AIS can be set to normal, receive only, or restricted. Also allows sharing of SAR patterns, targets, messages, ops reports, etc.
