Thought I would buy a scanner and found a Bearcat BCT-15X for about third the nominal price.
Seller noted it was dead, won't power on. Not much problem for me being a long time bench tech, so jumped on it.
Testing, I found the current draw met specs, power off to power on, well, power switching works but still DOA.
Some research, seems there is a 20 volt boost converter with a history of failure. Bought this tiny boost converter also on feebay.
Set for 20 volts, installed it in replacing the original. Now it functions like new and excedes all the specks. Sitting here right now, been running 4 years. Also did the discriminator tap mod. $200.00 if anybody wants it.
Years back, bought a General MC-11a with D104 mic, no TX for $25.00 at a swap meet(Wanted the mic). Replaced a burned screen resistor and worked like new. IF you find one today, working at all, over $250.00 and the mic like $75.00 an up.
Base antennas, JEEZ, a decent beam can run over $600.00, I bought a 5 element for $50.00. For mobile,
Bought a Hustler fold over mast, ball/spring mount and full complement of RMxx 1Kw coils( 80-10 + 11M) all under $100.00, priced out today will be about $400.00
And people wonder why CB is dying.
