SDRTrunk Using Multiple Tuners For Increased Bandwidth?
GTR8000
NY/NJ Database Guy
BEE00
769.45625 - 770.91875 = 1.4625 MHz
773.06875 - 774.78125 = 1.7125 MHz
2.048 msps doesn't give you a lot of buffer in the 773-775 block. The dongle could easily get re-centered to a frequency that puts 774.78125 on the fringe where coverage drops off, degrading decoding. I would stick with 2.4 msps for this site to be safe.
Get rid of the third dongle, set each of the two remaining dongles to 2.4 msps, then create two dummy channels for each dongle as detailed below:
For dongle one (covering 769.45625 - 770.91875)
- Assign this tuner as the Preferred Tuner for your existing Albuquerque Simulcast channel definition, since all of the control channels are in this block
- Create a P25 Phase I channel on 769.05 with 0 Max Traffic Channels and Ignore Data Calls enabled, and set it to prefer this tuner
- Create a second P25 Phase I channel on 771.25, same parameters as above
For dongle two (covering 773.06875 - 774.78125)
- Create a P25 Phase I channel on 772.85, same as above
- Create a P25 Phase I channel on 775.05, same as above
- Assign both of those to the second dongle as the Preferred Tuner
The net effect of doing this is that you are essentially forcing each dongle to focus on the spectrum between each of those two sets of dummy frequencies. Since those dummy channels are set to ignore all traffic, they serve no purpose other than to provide lower and upper limits for each dongle to prevent re-tuning.
GTR8000
NY/NJ Database Guy
BEE00
Sorry, I forgot one crucial step: set those dummy channels to Auto-Start before the actual simulcast site. The auto-start order should look like this:
1 - 769.05
2 - 771.25
3 - 772.85
4 - 775.05
5- Albuquerque Simulcast
GTR8000
NY/NJ Database Guy
BEE00
Here are some screenshots to illustrate what the setup looks like. Note in the two spectrum displays, those active channels on each extreme...those are the dummy channels keeping all the "real" channel centered where they are optimal.
GTR8000
NY/NJ Database Guy
BEE00
The setup has worked well for me even when there are a dozen or so simultaneous transmissions (TDMA system), but your mileage may obviously vary. Half the fun is experimenting to see what works best.
It would be nice if SDRTrunk provided a way to lock the center frequency of each dongle, but it doesn't, so I decided to try to come up with a clever solution to effectively force the dongles to stay put.
maus92
OCMD
I always thought that the traffic channel sdr was free to tune to any system frequency - in essence the tuned traffic channel would also be the center channel, and would change dynamically with retuning. I don't think I'm missing any transmissions monitoring a system with a 5 MHz channel spread using two Nooelec sdrs. I need to go back and look.
GTR8000
NY/NJ Database Guy
BEE00
Any dongle is free to tune to any frequency, provided that frequency is within the bandwidth window. To be clear, the dongles are not really "tuning" to frequencies so much as they are seeing and processing the entire bandwidth based on the sample rate. In many cases, the center tuning seldom changes, even while multiple frequencies are being decode simultaneously. If a dongle's center tuning is 770.00000 MHz and all control/traffic is occurring on frequencies between 769.45625 and 770.41875, and the sample rate is 2.4 msps, the dongle will never need to adjust its center tuning.
The dongle decoding the control channel also decodes traffic, so long as the traffic channels are within the tunable bandwidth of that dongle. Using the Albuquerque example above, the dongle that is decoding the 769.45625 primary CC is also going to cover any traffic channel in the 769 and 770 block.
Ryanwr944
I am having issues where every other transmission sounds garbled. Is there a setting I have wrong. Have gain on auto running both dongles at 1.800 MHz.
maus92
OCMD
Need more deets: target radio system, sdr models, antenna setup, audio setup, CPU loading.
