VIPER Statewide Radio System Discussion
All, if you have the ability to run Pro96com or similar that can look at the controller frequency of your nearby NC VIPER sites, I have already found 2 sites recently upgraded from P25 phase 1 to phase 2 and controller frequencies and being changed and /or added. One is Ahoskie that had one of the non controller frequencies designated as a controller while leaving the alternate controller and existing controller the same, and Winfall was using a controller frequency that it wasn't licensed for until the last 2 days or so since I checked it. It's been changed to one of the frequencies on the FCC License for the site now and updated in the listing. Makes me wonder what sites had other changes done as the system gets upgraded. If you have the ability to check sites near you and see anything changed that you can personally verify, please submit them. Thank you (I will be adding the link to submit the changes in a reply to this message)
Richard
It is very possible those are the test Control Frequencies mentioned in this post
trumpetman
Charlotte, NC
Nothing will change at the system level except for the TG type and that can be changed with the click of a mouse button. If your receiver is capable of TDMA, it will work just the same as it always does. Same control channels, voice channels, talkgroups, etc.
There are no test frequencies. VIPER will use the same control channels, voice frequencies, and talkgroups, but the modulation will change to TDMA. If you have found new control channels, it is because they were shuffled around, likely from the capacity build-out/realignment that took place several years ago now.
Thank you @trumpetman I have heard them using SW Event TG Tango and it sounds good at my location.
trumpetman
Charlotte, NC
I think many will be underwhelmed come July 1st. Without paying close attention or watching on a decoding program, most won't even know traffic has switched to phase II unless they realize they're missing traffic and only using a phase I capable receiver.
richardbritt
State of NC
Northeastern NC
I hope you are correct and it's seamless for everyone, since everyone had the heads up this has been in the works 2 years now. I just received 3 Bcd536 scanners to replace my old faithful pro2096 units. I just updated the firmware, upgraded to nxdn and dmr and programmed them as of last night
richardbritt
State of NC
Northeastern NC
The different control frequency wasn't reported by the same site about 2 months ago when I was driving around in that area and I had my laptop running pro96com and using a ws1040 scanner on the control channel. I always take screenshots when I drive to sites just in case I forget to write down everything on my notepad when I am away. It's easier to look at the screenshot if needed than drive a couple of hours back to the same site a 2nd time.
I have checked 5 sites around me today and every one I checked was as they were several months ago
Richard
I've been listening to test traffic on SW Events Tango 1-4 and have made NO changes to my scanner.
richardbritt
State of NC
Northeastern NC
It's very possible that the reason the Winfall site controller was changed was the fact that it had been a frequency that was not listed on the FCC License for that site, and it was changed to another frequency listed on the FCC License. As far as the Ahoskie site is concerned, no other frequencies were added, just one of the non controller frequencies was designated as a controller frequency but the existing controller frequencies was changed. So nothing was affected scanner listening wise. Probably changed by accident. I didn't see any other sites that were disturbed settings wise after the Phase 2 in my local area (I checked a bunch in the northeast part of the state in the past few days).
Richard
The below list is of unidentified TGs heard in the past week, in case anyone has any clue.
Talkgroup
RIDs Seen
RID Original seen TG
RID Agency
52845​
2143598, 2143659​
UNC​
52058​
2102511​
NC SBI​
52684​
2147500​
NC SBI Possibly​
52694​
1834576​
Raleigh PD​
52800​
2078471​
52572 WakeMed LE Disp​
WakeMed​
52259​
1844126​
Wake County SO​
52337​
2160xxx​
52803 (not in DB), 52160 (Trp C)​
NC SHP​
52338​
2160xxx​
52803 (Not in DB), 52160 (Trp C)​
NC SHP​
60809​
29153xx​
60810​
29153xx​
60811​
29152xx​
Helo "GUARD478" a SC ANG helicopter, communicating on Statewide Events TG Alpha 1 with Burke County on a medical run with RID 5547065
FJB2022
Talkgroup
RIDs Seen
RID Agency
52845​
2143598, 2143659​
UNC​
52058​
2102511​
NC SBI​
52684​
2147500​
NC SBI Possibly​
52694​
1834576​
Raleigh PD​
52800​
2078471​
WakeMed​
52259​
1844126​
Wake County SO​
52337​
2160xxx​
NC SHP​
52338​
2160xxx​
NC SHP​
60809​
29153xx​
60810​
29153xx​
60811​
29152xx​
52259 is Statewide Law. 52800 is in the DOC radios, along with 52801, 52802, 52805, and 52811.
52259 SW LAW was removed from the current template for Viper radios and removed from the database, and 52800 wasn't being used by a DOC radio, nor was it in that range for them which is 51615 to 51687 and 60918-60932 for probation, shared with Federal Probation (I have never heard DOC use any of the TGs you mentioned) as you can see below.
52799ce3fDLZ PIED 2LZ Piedmont 2EMS-TacState Office of EMS
52816ce50DSW CONFStatewide Conference ChannelInteropStatewide Interop
richardbritt
State of NC
Northeastern NC
The 608xx TGs should be federal going by the numbers. What agency, I dunno. Were they encrypted or did you capture any audio? How about date and time of use? Might help get a feel of the users. I'll plug those in my scanner
Richard
Richard
Those three TGs and RIDs have been a mystery for years, they are always encrypted and no other RIDs other than the 29152xx and 29153xx RIDs.
Today I wasn't listening full time, but here are the hits I got;
06/13/2025 12:31:31​
Affiliate​
60811​
T: 157 DT: 6/13/25@12:31​
2915283​
06/13/2025 12:50:42​
Affiliate​
60811​
2915283​
06/13/2025 09:43:17​
Affiliate​
60809​
T: 157 DT: 6/12/25@12:43​
2915319​
06/13/2025 16:12:23​
Affiliate​
60809​
2915319​
Affiliate​
60809​
2915319​
06/13/2025 16:14:27​
Affiliate​
60809​
2915319​
Affiliate​
60809​
2915319​
06/13/2025 16:08:48​
Affiliate​
60810​
T: 157 DT: 6/13/25@16:08​
2915327​
06/13/2025 16:12:30​
Unaffiliate​
0​
2915327​
06/13/2025 16:12:42​
Affiliate​
60810​
2915327​
06/13/2025 16:29:01​
Affiliate​
60810​
2915327​
06/13/2025 11:22:40​
Affiliate​
60809​
2915329​
Affiliate​
60809​
2915329​
Affiliate​
60809​
2915329​
06/13/2025 16:47:44​
Affiliate​
60809​
2915329​
06/13/2025 16:48:06​
Unaffiliate​
0​
2915329​
GMB2711
Spring Lake, NC
Wow I guess I need to start monitoring more, and was wondering if any Counties or Citys decided not to use Viper anymore due to P-2 and i will be looking for new TGs
BryanTheRed
NC
Is the data listed in the DB for the Concord site accurate? I added it to my G5 and get nothing, not seeing the site at all. Can pick up Heathway Dr just fine in downtown Concord though...
I'm guessing you have programmed it in as a separate site, not combined with the Heathway Dr site? In Raleigh there are three main sites and if I try to combine them two are silent, separately (one per knob) I pick them all up.
