What is a good antenna for all around use?
Cashanova48
GMRS callsign WSAF780
I am currently using an old radio shack pro-89 and a UV-5R, I am wondering what would be a good antenna for picking up all the first responder bands and some airband without costing an excessive amount of money but doing a relatively well job. I am planning on switching to a Motorola XTS3000 sometime soon and some time later to a Motorola base station, so it would need to be digital capable. Any response is appreciated.
Ubbe
Stockholm, Sweden
Does your digital antenna needs to sit on the scanner and later on a Motorola, using adapters, or can it be an external one and how a big size can it be, like a fullsize 1 meter high discone or perhaps even a 4 meter vertical? For general coverage a discone always works for VHF airband and up thru the frequency ranges, even if it starts to fall off above 500MHz but local 700-900MHz systems are perhaps of a good signal strength so probably no issue.
/Ubbe
Cashanova48
/Ubbe
Thanks, I was thinking about an external antenna. Is a diacone or vertical normally better for long range?
merlin
DN32su
For base, a discone antenna will serve you well.
For mobile, about any of the tri- band antennas.
Portable is hard to fit but a VHF rubber duck works OK.
XTS series, just get the antenna made for the radio. It will be band specific.
Base radios are usually XTL mobile in a desktop case. That you can plug in to the discone.
You won't be transmitting on the Moto's (very bad omen if you do) So no biggie there. No such thing as a digital antenna.
Cheers
Rt169Radio
CT
This antenna might be a good choice, I have it and it seems to pick up signals better then my discone.
Cashanova48
Ok, thanks
Brales60
Punta Gorda, Fl
Ok, thanks
I have that antenna and it's outstanding. Blows away my Discone.
Ubbe
Stockholm, Sweden
Discone have no gain so not for long range monitoring of weak signals. Vertical antennas can have gain by flatten its radiation pattern from where it does no good, up in the sky, and from down into the ground, to focus on the horizon.
/Ubbe
