The wider useable bandwidth of a quarter wave antenna would serve you better.
A 5/8th's wave would have more gain, but that's probably not going to be beneficial along the coastline, and the extra length will find all your low tree branches. Probably won't hurt the antenna, but it's usually not necessary for that sort of application.
I've almost always run 1/4 wave antennas on my radios. Those radios are usually loaded with not only amateur radio stuff, but work radio systems. Nice low SWR across the band, and the radiation pattern of the antenna works well.
My choice for antenna would be:
The Pulse-Larsen NMOWBQB is a 1/4 Wave whip with spring Omnidirectional Antenna operating at 150 - 170 MHz with NMO Mount Base This Antenna Requires a NMO Mount. Please click here to find all Thru-Hole NMO mounts or Magnetic NMO Mounts we carry.
www.arcantenna.com
I've run the Larsen antennas for 30+ years, both on my personal vehicles and at work. Never had any issues with them.
MOBILE, 1/4 Wave - VHF/UHF 108-512 MHz - Poly Spring & Std. Base
www.arcantenna.com
Recently, I've been using EM Wave brand antennas and am pretty well impressed. The base sealing design is a bit better than Larsen, but either one will work just fine. I've started using the EM Wave antennas at work, and so far I'm happy.
