Has anyone had to dispute the charge on their credit card for licensing Win500 and not being issued the registration keys?
His last post stated it was a Pay Pal only issue with the registration keys not being sent out, and credit card purchases were not affected.
It would be nice to know if some people are getting keys.
I've only read posts stating no key ever received. Of course most people would not post about getting a key.
buddrousa's last seen date is also much newer than the thread I recall where one of the mods here noticed his account had activity. That was older than 12/27/2019. Something must be brewing if we are seeing occasional activity on his account.
I hope he is still around plus still selling his software. I used to recommend it to many simply because it was simple to use and it worked very well.
I used Win500 a bunch for PSR500's and 600's. So much so that I wore the eeprom chip out in my PSR600. The memory cells started failing from too many writes. Don helped me with the part number of the chip and I was able to successfully swap it out with a new chip.
The original eeprom chip was automotive rated so it could handle higher temperatures. The con with this chip was it's writes per cell over its life was lower.
I replaced my chip with a non automotive rated chip that offered significantly more writes per cell over the OEM chip. I don't use my PSR600 in hot environments so heat was not a concern.
Don advised turning off the hit counter in the scanner as that is a write for each hit. If you need the feature, his Win500 software will provide hit counts without writing a memory cell with each hit. I did what he advised in my PSR500 and never had a problem with it.
I have seen others post here with apparent eeprom failure with their PSR600's.
