WinRadio Excalibur hardware and software use Hints and Basics (picture heavy)
widowsson
Goodyear, AZ
Hello, I'm new G31DDC user and I would like to try to use G31DDC hardware with the G33DDC version of the software. Can someone send me a g33ddcapi.dll or tell me where to get it? (PM ?) - the old link doesn't work.
Thank You
Yes, I can send it to you as soon as I replace my computer's motherboard, which should be by Wednesday or Thursday. I'll get you a Google drive link for you to download it. I'll post here for an update then.
Sent from my Pixel XL using Tapatalk
Montygew
There is now a third party .dll ( g33ddcapi.dll ) that allows a user to run the G33DDC Excalibur Pro software with the G31DDC Excalibur hardware. This brings some of the functionality of the Pro to the regular Excalibur. I have tried it, and it does seem to work, but I have been much too busy with work to look at it in detail or to add to this thread. I have a couple of ideas of guide/help things to throw in this thread, but have not had the time to do them.
What I know so far, running the G33DDC software with the G31DDC hardware does not activate hardware features, such as 4 MHz DDC record, RF front end BPF, or the preamplifier, this should be clear and obvious to anyone, software does not add hardware ;). A couple of features I thought would be software based appear to be hardware instead, and so also do not work with the Pro Software/G31DDC hardware combination, and that is the dual notch filter and the selectable SSB on ISB and DSB modes.
But, what does appear to work is the enhanced measurements capabilities, clock based time tags on waterfall displays, clock playback during DDC record, longer filter sample rates (improved filter performance), selectable RX to specific sound card outputs (VAC functionality), and several other more polished features.
Keep in mind that this is a 3rd party DLL. One can think of it as a “hack”. As such there might be issues that could void any warrantee if you decide to use the software/hardware combination. Look at it as you would any other 3rd party software, use it with caution and at your own risk.
T!
Hi i have the WINRADIO G31DDC but would like to run it with the G33DDC software. Could you please let me know where i can download the G33DDCapi.dll file from. I have read your post and it is excellent for anyone new to the Winradio (like me!) Many thanks.
Montygew
Is there a way to change the mouse wheel tuning step in WiNRADiO G31DDC. The default is 1Khz which seems high, i would rather have it set for 100 Hz. if possible and not have to use the Alt key.
