XG-100M Feature Codes
BMDaug
I am licensed…
Central Colorado, USA
Here’s the list of every Harris feature. Not all of them apply to every model.
01 Conventional Priority Scan
02 EDACS 3 Site System Scan
03 Public Address
04 EDACS Group Scan
05 EDACS Priority System Scan
06 EDACS/P25 ProScan (ProSound / Wide Area Scan)
07 EDACS/P25 Dynamic Regroup
08 EDACS/P25 Emergency
09 Type 99 Encode and Decode
10 Conventional Emergency
11 RX Preamp
12 Digital Voice
13 VGE Encryption
14 DES Encryption
15 VGS Encryption - User-defined speech encryption
16 EDACS/P25 Mobile Data
17 EDACS/P25 Status/Message
18 EDACS/P25 Test Unit
19 M-RK I Second Bank
20 OpenSky AES Encryption (128-Bit)
21 EDACS Security Key (ESK) / Personality Lock
22 ProFile
23 Narrow Band
24 Auto Power Control
25 OpenSky Voice
26 OpenSky Data
27 OpenSky OTAR
28 OpenSky AES Encryption (256-Bit)
29 ProVoice
30 Limited Feature Expansion (LPE-50/P5100/P5200/M5300)
31 Smart Battery
32 FIPS 140-2
33 P25 Common Air Interface (CAI) – P25 Conventional
34 Direct Frequency Entry
35 P25 Over-The-Air ReKeying (P25 OTAR)
36 Personality Cloning
37 EDACS/P25 AES Encryption (256-Bit)
38 Radio TextLink
39 P25 Trunking
40 700Mhz Only
41 VHF-Low (35-50)
42 VHF-High (136-174)
43 UHF (380-520)
44 700/800 MHz (Dual Band)
45 DES-CFB
46 Vote Scan
47 Phase II TDMA
48 GPS
49 Bluetooth
50 OMAP Wideband Disable
51 MDC1200 Signaling
52 C-TICK Certified Operation
53 Single Key DES
54 Control and Status Services
55 Link Layer Authentication
56 Motorola Multi-Group
57 TSBK on an Analog Channel
58 Unity Wideband Disable
59 eData
60 InBand GPS
61 Encryption Lite (ARC4)
62 Single Key AES
-B
wk14724
03 Public Address
04 EDACS Group Scan
11 RX Preamp
12 Digital Voice
13 VGE Encryption
14 DES Encryption
22 ProFile
23 Narrow Band
25 OpenSky Voice
26 OpenSky Data
27 OpenSky OTAR
29 ProVoice
31 Smart Battery
32 FIPS 140-2
38 Radio TextLink
39 P25 Trunking
40 700Mhz Only
41 VHF-Low (35-50)
43 UHF (380-520)
45 DES-CFB
46 Vote Scan
47 Phase II TDMA
48 GPS
49 Bluetooth
53 Single Key DES
59 eData
60 InBand GPS
62 Single Key AES
-B
Can someone explain what 16 actually does?
tweiss3
Is it time for Coffee?
Ohio
Dumb related question. My 100P lists most features by name, not number. Is there a way to read the features in RPM and associate them with the number, or get more information. Such as mine lists GPS, Bluetooth, then CERT 1 (unknown what that one is), then 54. I have to assume it is is a feature between 50 and 54, but doesn't quite make sense to me. Same earlier in the list, shows P25 Conventional, Encryption, Trunking. I have to assume Encryption is item AES, however, under Radio Info AES and DES also list (NONE).
BMDaug
I am licensed…
To be clear, there’s no hardware module on a separate board to install or anything. You need software ENC modules that you can load at will, just like burn/boot/firmware… you just need to get them from your dealer.
-B
Edit: Also, option 37 is all that’s required to do full multikey AES and DES encryption. Those higher feature codes are for single key DES or AES (also 61 is ARC4), so those are all of your encryption options, with 37 being the most full-featured…
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
There is no feature number listing available in RPM or the Maintenance Utility. If you had a mobile you could read them out by number if you had a CH-721 head but the CH-100 head acts the same as the 100P and gives you (mostly) names. A theory about why some are named and some numbered is that the numbered options were made compatible late in the product/firmware life.
CERT 1 is European ETSI certification, not Australian C-Tick. It's an empty feature just to show certification, there is no functionality added or removed.
BMDaug
I am licensed…
Remember that not all features apply to all radios in the Harris MA/Com lineup. The feature codes aren’t bespoke to any one model. Reading the release notes for the firmware version you are running is the best way to glean what requires a feature code and what is included in the particular firmware you use. 16 is old…
-B
redbeard
BEE00.348-3.1
16 is still a valid Unity option. It shows up on a 100P as 'P25 DATA'
But yes BMDaug is correct, not everything applies to all radios and many are old and deprecated. Everyone wants 34 in their radio and don't even realize it's baked in on the Unity line and just requires setting a maintenance password in RPM option.
BMDaug
I am licensed…
I didn’t say it was deprecated, just that they pretty much go in order chronologically. They have been added to and added to up until the XL line came out. Now it’s an encrypted xml file…
-B
redbeard
BEE00.348-3.1
I didn't say you said it was. I said many are, such as 34. 34 is newer than 16 and while 34 does not apply the older 16 feature does apply to Unity. So what order they went on the list is immaterial.
BMDaug
I am licensed…
And I didn’t say it was material… it’s just an example of how the feature codes work. I said three words and somehow prompted paragraphs of debate LOL!
Bottom line: Harris MA/Com piled on features for 20 some odd years and the only way to know what applies to your radio is to READ THE RELEASE NOTES.
-B
TDR-94
but the modules don't function without encryption or single opt 53 or 62
Since the XG-100P doesn't support Single-Key DES or Single-Key AES. Only ENCRYPTION (Multi-Key) AES-256, DES-OFB, and DES-CFB would apply to it.
TDR-94
-B
Also, some of those features only applied to the older 40-Bit feature encryption and others only apply to the newer 80-Bit feature encryption.
redbeard
BEE00.348-3.1
TDR-94
It doesn't support either. That's why there is no provision in RPM to create or select the single AES or DES keys. The same is true with ARC4/RC4 keys. You can add every feature code to the XG-100P feature list. The demo units had every feature code enabled in the feature list on those.
Is EDACS, ProVoice, OpenSky etc... supported ? Nope.
