XG-100M Feature Codes
radionerd1
LOL,
don't do it man!
I attached the wrong txt file.Look at this one
  • burnapp commands atz stuff.txt
radiotech33
County line road
Can I down load and read it ...
Thats interesting...Now with that being said..The xg75p is DOA..no boot...nothing .. so how do you communicate..seems hyper terminal dont work..?
radionerd1
No indication of power? ignition sense, internal fuse? bad wiring? bad data cable?
Most I've seen will show an Error, or LOST MRU...
It's been 5 years since I played with this stuff. I have a service memo sheet that has prolly aready been shared around here. It might help you if terminal still works, and you get errors.
  • fatal recovery XG100m TSM36-02C.pdf
merlin
DN32su
My first bricked XG-100 simply would not talk to the outside world. CH-721 head, it would send power on over the can bus and the brick responded, but no return data on the can bus. I JTAGed the mru and managed to get a recent burnapp and bootapp into the brick.
Still nothing on the RS232 and only one way on the can bus.
Conclusion was a hardware failure in the complex comm's switching to the OMAP. Means a new PK board.
:cry:
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
I'm going to dredge up this single key confusion again with a clip from the current XLP 17C firmware PDF.
So, ARC4? RPM2. Single Key DES? RPM2. Single Key AES, Key Admin/Loader or KVL.
BMDaug
I am licensed…
Central Colorado, USA
:cry:
To my recollection, the 100M is not an OMAP radio… (Not picking on you, just trying to avoid confusion.)
-B
Forts
Ontario, Canada
Yep that'd correct. Never made sense to me that single key AES couldn't be done in RPM2. And you can't use single key DES and ARC4 together.
BMDaug
I am licensed…
Ya, especially since I thought the whole point of single key AES was to lower the financial barrier to entry (as in, not having to purchase a $10k key loader suite, along with the feature costing nil). 🤷🏼‍♂️
-B
TDR-94
Single Key-AES keys have always been required to be loaded by a the L3HARRIS keyloader or a KVL for security purposes. Reference to Single-Key-AES keys needing to be loaded by the L3HARRIS keyloader or a KVL goes back to XLP-R6G (December 2018) SRN and maybe even earlier. That's just the earliest mention that I found doing a quick search.
merlin
DN32su
-B
100M uses TIs OMAP 5910 dual core CPU and has Altera's Cyclone III coprocessor.
nikronzo
because the 100M is a Unity Radio, hence Unity Wideband Disable Option 58
