XPR4550 programming woes
cpotter1112
Hoping someone can shed some light on this for me.
Picked up an XPR 4550, model number AAM27JQH9LA1AN. Made a programming cable. Using mototrbo cps v16 build 827. I get an error when I try to read the radio. "Error 1057, region not supported". It's my understanding that this radio and this cps should work together. Anyone have any suggestions?
Firebuff880
Boynton Beach, FL
Your understanding is apparently wrong --
The CPS at that level is Region Specific and the CPS binary does not match the firmware in the radio.
Not knowing the history of either the device or software not sure what to tell you to change out and I don't have a magic decoder ring for the model string handy.
cpotter1112
The radio is a north American radio, it was originally sold by a local shop. The AA in the model number dictates that. (It's also programmed with local channels). It's firmware version is R01.12.02. As far as I know the cps V16 build 827 should be the north American cps.
Forts
Mentor
Ontario, Canada
That version of CPS (as well as others of course) are available in different regionalized versions. Unless you downloaded it yourself from MOL. it's possible it's a different region. Have you read any other NA radios with this installed version of CPS?
K2NEC
I've seen an non-NA radio disguised as an NA radio. Just because the sticker says so doesnt mean the radio thinks so. Clearly this isn't the case but you can never be too sure.
cpotter1112
I haven't read any other radios. Buddy has a couple and I'm going to see if they read tonight. As far as I could find, build 827 is the north American region. I will have to do more digging.
cpotter1112
If I had bought it from ebay or something, I could definitely see that. But I don't think that's the case here.
cpotter1112
Again, Build 827, etc., has absolutely nothing to do with the region. 827 was available in every region.
That makes sense then. I thought the build numbers corresponded to regions. Guess I need to try to find the cps for the correct region. Thanks
cpotter1112
Well I got the right version and was able to get it programmed. Now if I can just find the RSS for a stack of 1225s, maybe I can get my workbench cleared by spring.
Thanks for the help.
