XTS 3000
Hello.
I am just wondering if there is anyone on here that can program in Talkgroups and add and remove Control Channels to an XTS 3000. Or if anyone on here can tell me how I can do it myself.
Me and a friend of mine did have someone do it for us before, we sent him our XTS 3000 file and he fixed it up for us, he added in anything we wanted, like any Talkgroups we wanted and any 4 Control Channels for the one file or each file we wanted done. And now for the past few months I haven't been able to get a hold of him anymore to continue doing this. He was a good guy and knew exactly what he was doing and how to do it. Once we got our file(s) back from him that we wanted done and fixed up, they all worked excellent with no issues so far.
There is some Talkgroups I would like added to a few of my files along with either adding or removing one or more Control Channels to one or a couple of my files as well.
So just wondering if anyone on here can do this or tell me step by step or whatever how to do it on my own.
I will be waiting for any replies to this post.
Ok. I don't really read those posts unless I need to. So don't know about it.
I would like to get these couple things fixed up, added and removed.
kayn1n32008
ØÆSØ
Sector 001
I would suggest to you that you REALLY NEED TO READ THEM.
While the audio is superior than a scanner, you are out of your league trying to program the radio. Get a scanner.
I'm guessing you are trying to monitor BMR Fleetnet... Some free advice: unless you are a legit user of the trunk system, the way you have your radio programmed is causing your radio to try and affiliate(the 'red flashing LED') to the system. By doing this you are trying to monitor you are breaking the law. If you are legit go to the system admin and ask for help.
I strongly suggest you go over to P25.ca and READ(do not ask because they will not spoon feed you the info) everything you need to set up your radio to not affiliate and still scan is there in that thread.
Also if you do find your way over to P25.ca I strongly suggest you NOT ask for a system key or how to make one. Nobody is going to give you a system key, nor will they tell you how to make one. Most likely you will just end up banned doing so.
Hopefully you are not causing havoc to a legit user by having a cloned ID
Sent from my iPad using Tapatalk
cabletech
Puget Sound
Here's my take on this.
coolguy is sooo cool he is like trying to pour molasses in sub-sub degree weather. He just does not get it.
He's been asking basicly the same question and getting the same answers for way over a year.
coolguy--get your head together and relize that you are not going to get any other answers then what you have already been told.
No body is going to "GIVE" you a system key or even want to program the radio because there are too many of us that RESPECT the verious systems that are in place.
Do us all a favor, turn the radio off, take the battery off and then put it in drawer and go get a scanner as you have been told several times.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I think we've all made our thoughts on this subject very clear. Hopefully Coolguy will take advice and get a scanner.
