Xts3000 P25 conventional question
JJones27320
Reidsville, NC
I have an xts3000 that has a Flashcode for 3600 SmartZone analog and p25. It works fine on that type system. I wanted to be able to listen to a 9600 p25 system. I know the Flashcode doesn't support 9600 trunking however is it possible to just program the voice frequencies into conventional and just monitor in non trunking? I attempted to do it but only got raw digital signals and no decoded voice. The system I want to listen to only has 3 voice channels it shouldn't be hard to follow in conventional mode.
FFPM571
Nashvillle
I do it.. you have to have the correct NAC and make sure the personality of each frequency is set to ASTRO
Project25_MASTR
Millennial Graying OBT Guy
Texas
So an XTS3000 will work on a p25 system? What about a mts800?
A XTS3000 with a digital firmware will work with P25 Phase 1. I actually have several Astro radios with analog only firmware in them.
MTS800 is an analog radio.
Sent from my SM-T350 using Tapatalk
mikewazowski
Staff member
Forums Manager
Oot and Aboot
An 800MHz XTS3000 with a specific firmware release and the correct flashcode will do P25 trunking. There are not very many XTS3000's out there with this combination.
The OP is scanning a P25 system as conventional channels hence his need for a NAC.
