XTS3000 receiving issue
rnemtb2
Tinton Falls, New Jersey
Good morning,
I have programmed an xts3000 vhf and I can not hear on reception. I double and triple checked frequencies and pl/DPL tones. Any help is greatly appreciated. Below is information from radio.
When in service mode the following comes up
R.07.25.00
DSPN 08.03.03
Flashcode 580001-001A00-7
I used cps R.05.03.00
I know I’m missing something can’t figure out what I missed.
Thank you
George
MTS2000des
5B2_BEE00 Czar
So if you program a NOAA WX frequency in your area that is strong, you hear nothing? Could be way out of alignment, bad RF board, antenna connector itself...25 year old radio....start with the basics. If you program a simplex freq in carrier squelch and key up another known radio on that frequency or the NOAA WX signal, what do you get?
FKimble
Newnan, GA
Remove all the tones. Don't need them to receive. They can keep you from receiving a transmission with out a tone or the wrong tone. To hear everything do not use tones!
And as mentioned program in the weather (NOAA) frequencies and verify you can hear them. If you can't receive NOAA, them you probably have a radio problem or programing problem.
Frank
rnemtb2
Good afternoon, sorry late responding to this work has been crazy. found my issue, Forgot to add channels to scan list. receives fine now. So thank you all.
I now have one channel that will receive off of scan mode, but will not receive when in scan mode. I can transmit when in scan and off scan . I know I must be missing something .
Again thanks for all the help
