xts3k read issues
sr5295
hey guys looking for some help also trying to get my xts3k to read having issues using the following setup
windows 7
using serial programming cable to serial-usb dongle (from valley enterprises)
tryed using multiple cps versions
ver r05.03.00
ver r10.00.00
ver r14.00
ver r16.01
ver r17.01
ver r19.01
any help would be great
K2NEC
windows 7
ver r05.03.00
ver r10.00.00
ver r14.00
ver r16.01
ver r17.01
ver r19.01
What error are you getting?
DPapay
Morris County, N.J.
XTS3000 uses it's own software, guessing by those versions you listed, I would guess you are trying to use the Astro 25 software.
Astro Saber and XTS3000 CPS
Version 5.03
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
USB to serial dongles are very hit-and-miss.
Get a Dell latitude laptop for 30, 40 bucks off ebay. D620 or D630 or D820 or D830 models.
They're the most bulletproof and reliable laptops for programming Motorola radios from the pre-USB programming cable days.
Never trust a USB to serial adapter. They are far from 100 percent reliable.
ME801
NV
only a 32 bit computer with serial port will work with Astro/XTS3000 CPS
chrismol1
P25 TruCking!
The only correct version is XTS3000 ASTRO SABER version 5.03 is the latest
not Astro25
If your using a usb - serial do you have the correct drivers installed and make sure the usb comm port in Device Manager is steered to the correct COMPORT you will use in the Astro software
sr5295
got it
thank for the input everyone was able to get it with one of my old laptops the issue was running 64 bit needed the 32 bit but I also was able to get it to work with the ribless cable
