XTL/XTS5000 XTS5000 Type II Scanning
Lonnie_
Texas City, TX
So I finally got the right cable and have started to program everything I want on it but when it comes to type II I'm not really sure what I'm doing. I'm mainly concerned about it affiliating to the smartnet system and my radio being bricked. Is there a way to non affiliate scan a type II smartnet system or will it always affiliate? I'm mainly confused since under the "Type II" submenu in the "trunking system" menu of the programming tree, it says "Affiliation type", I've attached an image below.
gtaman
GALAXY 19 91.0° W
Lonnie_
Texas City, TX
Ditch the XTS5K and get an MTS2000. So easy to NAS with them. All you do is program like normal with system key. Then set affiliation to PTT then set the top secure switch to TX disable.
I was actually looking at those before I bought the 5000. Should’ve done more research lol.
chrismol1
P25 TruCking!
MTS2000s. They're perfect for old 3600 smartnet systems as instruction above stated. The 900's you gotta look for the model number. You'll need to find a "W" in the beginning instead of "U"
W=900
U=800
So H01Wxxxxx would be a 900 model
chrismol1
P25 TruCking!
Forgot to add, you'll need one with the trunking package in the flashcode
At least in my experience every 900 MTS2000 I've acquired seem to have minimum basic flashcode of 000004-000000-6 H37 smartnet
Lonnie_
Texas City, TX
Just another question about the XTS, I saw somewhere on here that it can scan talkgroups listed with T? Trying to see if I can get at least something out of the 5K before I decide to get rid of it. For reference, I live in Galveston County and most of everything down here is on TxWarn which is a phase II system so I l’m gonna assume I can’t use it for anything in my county.
Giddyuptd
Here and there
XTS will only do phase 1. The only time it'll go back to phase 1 from 2 is a radio affiliates on that talk group in phase 1 if the subscribers and system is designed to do so.
natedawg1604
Colorado
You can definitely get XTS 2500s in 900, I got one recently really cheap for ham use. I'm guessing they are easier to program than MTS stuff, but I've never used anything older than XTS/XTL myself.
nhfdcadet
GCT-1
New Hartford, Ct
the only ways you should scan a trunked system is either entering the voice channels as conventional channels and scanning them, or buying a scanner. Then you wont have to worry about affiliation at all, or risk having your radio and computer confiscated.
chrismol1
P25 TruCking!
Correct me if I' wrong, is Astro25 firmware hardcoded to affiliate, only available as Automatic, whereas the the MTS/MCS the option to PTT on affiliate is available for old type 2 systems
