Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > Utility Listening
Utility Listening - Discussions regarding monitoring government, military, aircraft, ship, and other misc communications in the HF/MW/LF bands.
Old 03-21-2018, 6:42 PM
bearcat012's Avatar
Default 10715 khz YL Numbers in Spanish
at 22:40 UTC, 10.715 MHZ, AM, YL with numbers and digital bursts in Spanish.
Semper Fidelis
Old 03-21-2018, 7:04 PM
Wiki Admin Emeritus
Enigma station HM01- the Cubans are at it again (heh)...Mike
co-author, HF Digital Decoding
Old 11-12-2018, 5:19 PM
GB46's Avatar
I'm hearing that number station right now at 22:14 UTC on 10715. Has anyone managed to decode those data bursts after every 5-digit group, or at least identified the digital mode used? The sound reminds me of the 57k baud modem I had back in the 90s for making dialup internet connections.
Some spy agency! They continue to use the same frequencies that have been widely known for years and are so predictable that they are listed in EiBi's shortwave schedules.
Their signal strength on my R75 is S9+10db, with very minor fading and clear audio. It's just as strong on my portable, too. This is with a 23 ft. reel antenna indoors on both receivers. Funny, but RHC never comes through that loud and clear, even though they're probably using the same transmitters..
Old 11-12-2018, 6:21 PM
Wiki Admin Emeritus
It's very likely RDFT, which is a mode associated exclusively to HM01. There is an app that supposedly decodes it, but from what I have heard, it's a bit dodgy and it's stability is not all that good. Even if you decode it, it's all letters and numbers, much like what the Russians (and others) do. A quick search of the UDXF logs confirms the guess.
Old 11-12-2018, 7:30 PM
GB46's Avatar
So perhaps the data sequences are simply echoing the voice transmissions. I once tried copying out those number groups to see if any of them were repeated, but that was before the data streams were added, and there were more of the groups. I did manage to see entire sequences repeated.
To the uninitiated, sequences of letters and numbers are meaningless anyway, as are the codes read out on the US GHFS frequencies, but they do add a sense of mystery that makes SWLing more interesting. Come to think of it, I don't understand most of the languages used by the shortwave broadcasters, either, but it's still fun to hear them.
Old 11-12-2018, 8:08 PM
The software is called DIGTRX. I believe it was written for Windows XP. Under XP it is fairly stable, however there are issues running it under newer OS's.
RDFT was a ham mode before SK01, and later HM01, adopted it.
The HM01 files are encoded before being sent. DIGTRX will demodulate the transmittedfiles, but not decrypt them. So you end up with a txt file, but it is still encrypted. That is, assuming the Cubans did their tasking correctly. It is reported that on at least one instance SK01 (the predecessor to todays HM01) sent a message without encrypting first, so that the DIGTRX demodulated txt file contained real words.
T!
