If you're just wanting a feed to stream then yeah scannercast will work fine. If you're wanting it to stream on a mobile device and you don't want the constant hum of noise when there is no scanner traffic you can set it up using a walkie talkie app. I wrote a short how to on this thread covering that. http://forums.radioreference.com/st...dio-recording/316470-help-new-guy-please.html Either setup is easy to do. I just didn't like the constant noise in the background whole streaming on my phone so I set mine up with zello. Don't forget to forward your ports if you go the scannercast route.
I would like to set up a private feed using RR. It looks like that was offered as part of a premium subscription. I can't seem to find out how to sign up and then set my feed to private. Any help would be appreciated.[/QUOTE
We don't do private feeds as you are asking for.
You can do that your self by broadcasting what you want & then connecting directly to your feed.
I would like to simply just broadcast my scanner feed from my home and be able to access it from my iphone and also be able to let only me and my family and friends to access it. I already provide a feed but i wnt to be able to listen to all the channels without a TOS violation.
