AnyTone programming help
Dispatrick
Bergen County, New Jersey
I just purchased an AnyTone AT-518UV II, I downloaded the software and I'm a little confused on how to use it. Im very familiar with other radio software programs but this one is a little confusing. Im not sure how to program in a frequency that is on a repeater and its simplex channel. Also can I set this radio to display my ID number/name for when I transmit?
thanks!
Observer411
Lancaster, CA
If its like the 3318/termn8r software you have a TX and RX frequency manually.
You need to do the "offset" mathematically on the transmit frequency. (145.000 with +.600 offset would be a transmit channels of 145.600)
If you bought it from wouxun.us - Ed is very helpful and would probably straighten things out
Dispatrick
User Manual?
does anyone know of a User Manual available for the software "QPS518UV_1.01" searching this does not return any results in google. is it called something eles?
