Champaign County METCAD - Digital Interoperable Communication Environment (MDICE)
Starcom21
IL /MO/Global DB Adm!n
MetroEast-St Louis
http://wireless2.fcc.gov/UlsApp/ApplicationSearch/applFreqSum.jsp?applID=3896373
http://radioreference.com/modules.php?name=TRSDB&sid=4403&d=trsinfo
101Simulcast System866.06250866.55000866.80000867.10000867.56250868.13750868.52500868.82500
Towers at
1905 E. Main St. - Urbana, IL CHAMPAIGN County 40-06-43.5 N, 088-10-59.0 W
1000N/County Road 1900E - Sidney, IL CHAMPAIGN County 40-01-36.0 N, 088-06-18.6 W
307 S. Randolph - Champaign, IL CHAMPAIGN County 40-06-49.4 N, 088-14-47.7 W
1390 County Road 2600N - Thomasboro, IL CHAMPAIGN County 40-15-14.4 N, 088-11-40.9 W
2603 West Bradley - Champaign, IL CHAMPAIGN County 40-07-35.0 N, 088-17-25.0 W
By the way, I've updated the StarCom21 page to include a new "window" with the information for the system.
Let me know how it works for you all. Will update it soon.
http://www.StarCom21.com
cubn
Search, Listen and Submit
Marion/Johnson County, IN
[URL="http://www.StarCom21.com"]http://www.StarCom21.com[/URL]
I like the window idea since the info there is not stuff that I need to read everyday, but is a good reference when I need to see it.
We'll keep an eye on the MDICE system as testing starts to occur this summer.
Central IL
So, which digital scanner should I get if I want to be able to monitor this system and the ISP on Starcom when they migrate? What about rebanding?
cubn
In Champaign, either the Pro96/2096 or Uniden 396/996 scanners would work. Some areas in Illinois use 700 MHz frequencies for Starcom21. In those areas, only the Uniden scanners could properly trunktrack those sites.
thomasyu
Control Channel Active
As of 5/23/2007 there is an active control channel present on 868.8250 showing SID:01DAh-0101. So far I have not heard any traffic on the system.
bob_leach_3
Ashmore/Charleston, IL
MDICE System
That's cool that the control channel is active as of today. Does anyone know the approximate range to receive the system's towers? I assume they're not too far having so many towers. I'll try to receive it when I get home later. I can just receive the old 453... channels all the way to Charleston, even clearer at night. And the VHF fire freqs come in nearly all the time.
cubn
The only TG I heard last night was brief testing on 21002.
I'm not sure about the range of the system or if all towers are online. I was listening on a 396 last night and the signal decoded great here in Urbana. If you listen to the control channel itself it sounds really "messed up" compared to the Starcom21 Champaign site which sounds clear and strong. I don't know if this is a fact of it being a simulcast system and I'm receiving multiple sites or what.
gabbott
DeForest, WI
Control Channel
It should sound better tonight.
cubn
FileVersion:3
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 1da
System Name :
WACN : bee00
Tower Number (Decimal): 101
Tower Number (Hex) : T0101
Tower Description : (null)
Control Capabilities : Voice,Registration
Call Sign(s) : MDICE
Timestamp : Thu May 24 16:56:46 2007
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth
00,851.00625,0.00625,-45.00000,"Confirmed",0.00625
01,762.00625,0.00625,30.00000,"Confirmed",0.00625
-Frequencies
#Format: Channel,Usage,Frequency
"00-2409","i",866.06250
"00-2487","v",866.55000
"00-2527","v",866.80000
"00-2575","v",867.10000
"00-2649","a",867.56250
"00-2741","a",868.13750
"00-2803","a",868.52500
"00-2851","c",868.82500
Apparently the Thomasboro site is not online. On I57 near Thomasboro, the signal starts to fade and by Rantoul/Ludlow, there is no signal at all on this system. Similarly, I had to get south and east of Fisher til I could pick up the signal (this was testing using a 396T with stubby 800 MHz antenna)
thomasyu
It appears that they may be making preparations for some type of patching. Techs were very active on TG 21002 asking to have various fire channels keyed up from the console. Also all police Metcad police activity was on Channel 5 for all agencies this afternoon, there was no traffic on any other channel. I presume this is related but I’m not sure.
jasonpeoria911
Peoria, IL
Now that is a great public oriented thinking. I have great respect for departments that acknowledge there scanner listeners out there and know they can possibly help out at times.
Jason
k9swx
Champaign, IL
Now if we could just get them to subsidize some digital scanners for us. :)
KD4YGG
Truly good news!!!
Looks like someone actually recognizes the true power of citizen policing.
Encrypt the stuff that needs to be encrypted, and allow the public to be able to hear what needs to be heard.
Super!!!
cubn
Most, if not all the sheriff's dept is using MDICE radios on TG 21501 which is cross-patched with 453.900/453.150 (8/21/07). Some of the rural pds are using the new MDICE radios as well.
