intiractive
hello everyone. i live exactly 5 miles from the ocean and intercoastal waterways in wilmington, nc. i have a uniden bearcat scanner that i have channel 16 on the marine band programmed in that i like to monitor during the summer due to high volume of boat traffic. i use a boat marine radio antenna 1/4 wave that is mounted to the side of my house above my window (maybe 10 feet off the ground).
i can hear all the base stations like the marinas, the docks, the bridge tender for the draw bridge, the coast guard etc, but 90% of the time i cannot hear vessel to vessel traffic. would there be any benefits of relocating the antenna to the top of the tree out my window (at about 30ft up in the air) with db loss for the extra coax?
the antenna only came with 10 feet of coax connected to it. can i get more coax and use a bnc to bnc barrel and connect them? i know that will be more db loss by doing that.
i have a 8 foot ground rod right outside my window that i put in, how should i connect the ground wire to the antenna?
thanks for any tips yall can give.
