Tytera UV-380 says it is keying repeater but it is not
Have a strange issue, I have a UV-380, when I key up on a channel that I know I am out of range of I get the "outgoing call screen" even though it does not key the repeater. Other channels do not have this issue that I try to key up out of range on. How can this be fixed or is it just an issue with it being a CCR? Thanks.
belvdr
If you key up, it’s going to transmit regardless of what can receive the signal.
belvdr
I don’t have experience with that radio specifically, so maybe there is something unique. Any other radio I’ve operated, if you push PTT, a signal is generated from the radio. I don’t know why this radio would be different.
mancow
N.E. Kansas
If it's simplex it will do that as it has no feedback from a repeater. Check your programming.
KE5MC
Lewisville, TX
EMSF,
Not having any experience with that radio, my suggestion is to very closely compare all the data between channels that have the issue and don't have the issue. Obviously there are differences that are needed. As you know DMR programing has check boxes and links to other parts and they are not all clear about the end result.
Good Luck!
Mike
paulears
Lowestoft - UK
I have a number of DMR radios and one refuses bluntly to play ball - I get the warning on transmit that the repeater is not responding. Other repeaters are fine. It seems that some respond but won't let you through, but others refuse to handshake. Other radios don't do the message, but they don't get in either.
hill
Middle River, MD
As others have said sounds like you have the transmit frequency set wrong and could be set to same as receive (simplex). If it is set up wrong it will always transmit.
Review your programming to make sure that channel is programmed correctly.
You could post your programming file here and others could look at it. I will be at an all day event and won't be to look until tomorrow.
Going forward if you are out range of the repeater you will get a bonk when trying to transmit.
I have reviewed my programming and recreated a codeplug and I still get the same result. I notice when I put the radio into CH mode to MR mode, I notice the frequencies I have issues with have a frequency of 450.000. I suspect that could be the issue, how would I go about fixing that.
hill
Middle River, MD
450.000 sounds like the default frequency for that channel.
It looks like you need to change the 450,000 to whatever frequency that is required for the repeater.
