ChrisABQ
If I'm correct, you don't want to roll back further than 1.11.17, these are the upgrades for ProVoice and DMR.
Allright, here it goes. As I previously stated in the first posting on this thread, I downloaded the current firmware update. It was a disaster! 24 hours later I'm better off than before I started with the download.
Thanks to the help of many members, my problem is solved and my 436 ~ 536 is working better than ever.
First; Changed the threshold mode from auto to manual. Verified the theshold level at 8. Changed the modulation to NFM,
The scanners have not worked this well since I purchased them.
Just a reminder to everyone, this worked for a P-25 system.
Thank you to everyone involved with this thread.
The firmware was listed as experimental. The use of this type of software is best left to experienced users as often some features are not properly integrated or may be missing entirely. It is not unusual to have to tweak settings to locate the optimal values for either the specific user or for the item being tested or worked on.
Uniden is smart in configuring the units so that they can be rolled back to a previous firmware versions.
Unman, I know your out there hope you're working on a permanent fix for all these problems, brought on by the last firmware update. Please let us know!
How do you change those settings when you are "in the field" and already have systems scanning?Allright, here it goes. As I previously stated in the first posting on this thread, I downloaded the current firmware update. It was a disaster! 24 hours later I'm better off than before I started with the download.
So did you keep the current, most up to date firmware or did you revert back to the older version?
Sent from my XT1254 using Tapatalk
I'm stuck with the 1.11.20 update. I don't know how to revert back to firmware before this one. People are saying they revert back, I've asked twice, but no one answers my question how to do it!
I've called customer service today, The Tech, Mariano, said I'm the first call about this issue. He has no answers, sending this up to corporate.
Oh boy! Where's Paul Opitz?
First question. Do you have a copy of the previous firmware? If yes, here are the steps to reinstall it.
Connect your scanners USB cable to your PC. Select Mass Storage on your scanner. Open Windows File Explorer.
Your scanner should show up in Windows File Explorer.
Next, copy the appropriate "bin" file to the "firmware" directory that already exists on your scanner.
Finally, cycle power.
No, I don't have a copy of the previous firmware. How can I get it?
