linuxusr47
- Joined
- Apr 27, 2008
- Messages
- 10
I need help identifying a signal on about 1.776mhz. It is a data signal and is best heard on LSB. Here you can hear the signal: http://pages.suddenlink.net/k5oai/audio/1736noise.mp3 I tuned slightly off the center so the intermittent tone is audible.
Here is the history of this signal. As of Nov 1, 2009 I started having an increased noise floor on my receivers that covered from 1.710mhz - 5.0mhz. (By noise floor I mean the usual atmospheric hiss that I hear on the receiver) My usual noise floor was from an S3 to an S7 depending on the frequency. Now it is an S9+5 or more. This makes listening on 160m impossible as most signals I receive (when the noise floor is not that high) are copied about S5-S9.
I traced the signal's originating source down to the 1.776mhz data signal.
After a week (Nov 1-8) the signal went silent for a week.
So I had my normal noise floor and nice quiet listening from Nov. 9-15.
Monday Nov 16 it was back and is still there today Nov 21.
There are a number of 160m contests coming up in the next month(s), so I am hoping to find/fix this problem soon.
Clues that I have gathered so far.
The 1.776mhz signals are loudest during hours of darkness.
About 15-20 minutes before daylight the data signals drop from S9+10 to S7-S9 and the noise floor also drops some, but continues to be 3-5 S units higher than it should be. Forcing me to listen only to signals above 5.5mhz where the noise has dropped back to my normal noise floor.
All I have been able to search out is that, the range of frequencies are allocated to:
"1.705 - 1.800 Fixed Service Land/Mobile/Marine "
I live in a 2 room apartment on the bottom floor and external antenna possibilities are extremely limited, as are any kind of large indoor loops.
Any help identifying the signals so I might speak with those that are doing the transmitting would be helpful. I have lived here for 4 years and use 160m daily, so I know this is a new transmitter. Also there is no BPL here in our area.
Thank you for any help with this problem.
