10 Codes and other Codes
skippy2661
Mt.Airy NC
Does anybody have a list of dispatch 9-1-1 communication codes + 10 codes for North Carolina (Surry County)?
IcomIcR20
I was actually looking for the same thing since I just started running a feed for Surry County. Not really seeing anything concrete online. I'll look into it and let you know if I find anything.
(saw your message about the audio cutting off on my feed sometimes, so I moved the antenna just a few minutes ago and the control channel seems to be stronger now, so hopefully the dropping out will stop. Just let me know if it continues)
If you need 10 codes for other counties/agencies (like the Highway Patrol), I have some of those. Just let me know :)
skippy2661
Mt.Airy NC
Thank you,I have googled and searched everywhere I know to and have printed out 4 or 5 of them, but listening and looking at them I can definitely tell that these are not the ones they are using.Do you have Surry County EMS?
JDrisc3480
Fayetteville, North Carolina
You could try the non emergency dispatch number to see if you can get it from them, or you could try the EMS folks directly to see if they will give you anything.
IcomIcR20
I contacted Surry County 911 communications and was sent this file. Should be just what you are looking for!
  • Surry County 10Codes.pdf
spacellamaman
what kind of magic words did you use? did you have to sweeten em up first? compliment them on how sexy they must be in real life based on the sound of their voice? blackmail? simply asked (yeah right, cause that would work)?
whats you secret?
spacellamaman
IcomIcR20
whats you secret?
I have my ways ;)
But seriously, I just sent an email to the address listed on their website and heard back within a few hours with the PDF.
i am pretty sure there are at least a couple of 10-codes added since that lists revision of 2012, ones that i haven't determined what they are as of yet, anyone familiar with any added since then to the NCSHP list?
I listen quite a bit and have not heard any codes that were not on the list.
BCasto
Morrisville NC
The PDF file of 10 codes doesn't agree with the one I believe is being used in Wake County.
There certainly may be changes in the ten codes, but I haven't noticed. It'd be nice if someone, or a friend of someone, could get an updated copy.
viper36
Weaverville, NC
There is an updated file here on RR, dated 02/2013. Ten codes added are 10-92, checking a school. Signal 31, responding to active shooter.
