11 meters
K180
who have you contacted on 11 meters other wise known as cb radio please tell us all who you talk to. I talk to people in NJ and OH when I go between the two states I monitor ch 19 in both states my handle is K180 so if anyone wants to talk I will be on around 21:00 hrs. or 9:00 pm hope to hear from you currently I am in Cincinnati OH right now
singed
K180
robertmac
Since 11 m is not a ham band, this should be under the CB forum. I gave up on 11 m noise years ago after it became a bottomless pit. There may be some sensible users still on 11 m but are few and far apart. Edited as I see it was moved to the CB forum.
K180
11m
the thread Making Contacts / On the Air should be renamed for ham radio's people making contacts on the air not making contacts on the air because that sounds like any radio contacts on the air should be allowed
thank you
rick tucker
K180
robertmac
thank you
rick tucker
K180
But the Making Contacts/On the Air is in the AMATEUR RADIO thread. Along with the other Amateur related posts/threads. 11 m band hasn't been an amateur radio band for at least 60 years. Thus posts about contacts on 11 m belongs in the CB Radio Form-Discussions regarding Citizens Band Radio [CB]. As well if you haven't read or looked at the large number of threads in this section, you should as it includes a large number of posts on contacts on the 11 m band.
K180
11 M
then you need to put a thread tilted Making Contacts / On the Air in the CB Forum as well as in the AMATEUR RADIO forums
robertmac
Well, it isn't up to me, as I am not an administrator. You could as an administrator to do it for you. But you have to remember that CB radio was intended for short range communications, no long range. Most long range [not all because one can do it with 4 watts] use illegal amplifiers. Thus CB was not initiated for DX. It is only done illegally. As I stated before, there are numerous threads already on the CB forum about contacts.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
If you want a thread called Making Contacts/On the Air in the CB forum, then start one. Nobody is stopping you.
The Making Contacts/On the Air forum is a sub-forum in the Amateur Radio group of forums. CB posts clearly do not belong there.
Since we only have one CB forum, you'll have to settle for a thread.
