Unknown 14102750 KHz Digital ??
majoco
Stirrer
New Zealand
Right in the middle of the 20m amateur band it could be anything - maybe even some people trying out yet another digital format!
Saint
Fort Erie Ontario Canada
I tried most of the decoders i Multipsk but nothing worked, I was just wondering if it could be decoded. Thanks for the reply.
Steve
jwt873
Woodlands, Manitoba
I haven't done much digital on 20 meters for years.. I tinkered with 300 baud packet, AMTOR and PSK..
I just took a listen at 14.102 and man... Never heard so many strange squeaks, squawks and buzzes. :)
The signal you're hearing sound like Clover 2000 --> CLOVER 2000 - Signal Identification Wiki
Saint
Yes it's the first time I came across this kind of digital signal, There was a RTTY contest going on at the time and a lot of RTTY traffic, maybe someone was testing their rig out or something, I'll keep an eye out for it again.
Steve
inmarsat
Niagara Falls, Ont
Wow that really sounds like hf packet maybe its "network 105" off frequency did you try decoding in LSB? As too clover 2000 i dont think it is it was it ever legal in the ham bands idk. i use too work a lot of clover 2 at the turn of this century was always on LSB at 14.065 miss it as i miss all the pactor amtor and g-tor qso which were abundent in the 1990s....73 de VE3BEE
Saint
Thanks for the information I see the signal all the time, last night I tried to decode it again but with no luck, I will try and decode it with LSB and see if that will do the trick, I will post my results.
Steve
jochenbrandt
I checked the web site for digital sounds and could not find what this is, any idea. 14102750 KHz USB
Steve
I heard the same on 30m around 10.148 USB. I checked it out with MultiPSK....: Its APRS 300 Bd (Packet protocoll).
n5pwp
Spring, Texas
Steve
Could be VARac. This frequency just happens to be slot 3 on 20M. The calling frequency is 14.105.000. Each slot is 750Hz wide. VARA modem searches for the appropriate protocol to use for the current band conditions. So you can hear a variety of sounds on the slot frequencies.
Mike
merlin
DN32su
I have been catching som odd digital on 20. My first hunch is someone using VARA.
There are no restrictions on digital modes except for encryption.
sunwave
Oklahoma
Steve
Tried to get a match on Sigwiki but none sound like it. Almost sounds like Clover I. But those modes have a higher pitch than what is in your audio. I would try the signal centered on 1500hz in upper side band. Then maybe a match can be found.
