Those would be Inmarsat-C signals, used for marine services - messages to ships in the ocean, weather etc.
Up around 1544-1556 you'll see some more spikes carrying aviation data to aircraft. These are the aero signals broadcasting Air Traffic Control messages via satellite.
have you tried Scytale-C decoder yet on the narrow spikes?Thanks, I am aware that this is within the Inmarsat range. I'm more interested in the protocol/mode being heard.
the mode is NFM or sometimes a bit wider. The software is Scytale-C:Thats awesome what mode would that be.
Regards Lino.
sorry mode is USB.Thats awesome what mode would that be.
I thought all you need is a Bias-Tee to power it up according to the RTL website.
Will the patch antenna work with a SDRPLAY......The rtl-sdr.com active patch antennas only need power as you say....they already contain LNA circuitry.
Does anybody have a link for Jaero thanks no internet atm on my phone.
Thats what I meant to say,thanks ..........If you mean can they be powered by the sdrplay bias-t then yes.
i use this patch antennaWill the patch antenna work with a SDRPLAY......
thebaldgeek i think is his name should have some helicals for sale on his site if you wanted to buy one. How to build an L-Band ground station.i use this patch antenna
RTL-SDR Blog Active L-Band 1525-1660 Inmarsat to Iridium Patch Antenna Set
This is an active (amplified + filtered) high performance RHCP patch antenna designed for receiving L-Band satellites such as Inmarsat, Iridium and GPS. Easily mountable outside on a window, surface, stick, tree branch etc. Comes with easy to use mounting solutions and extension coax, and is...www.rtl-sdr.com
with SDRPlay and a SDRDuo with built in bias-T.
works great considering $50 price tag for the antenna. Working on upgrading to a helix when I can. SDRPlay works great with decoding software.
I have one, excellent antenna, his workmanship is top notch!thebaldgeek i think is his name should have some helicals for sale on his site if you wanted to buy one. How to build an L-Band ground station.
