166.300 N68F
Marcy57
I happened to be monitoring 166.2875 which I got N68F on last night and looked at the SDR
and went to 166.300 was P25 in clear ...mentioning "Watch Hill" the only "Watch Hill" I know is
RI?....and 4F9 so it,s NPS....73,s Marcy
(Could be diff. Watch Hill I,m sure , there is a "Watch Hill area on Fire island here?)
Marcy57
Ok tks it was strong and Fire Is. is right near me so probably...73,s Marcy
Marcy57
4F9 replies to the 68F op like 68F is the like the Dispatch or similar?...Marcy
ecps92
Taxachusetts
166.3000 is/was the input to 171.6250 NPS Fire Island
See if you get both at the same time
dlwtrunked
So you are hearing both $68F and $4F9 on 166.3000 ?
Could be two different repeater inputs, each using a unique NAC
Related: I sometimes look directly at audio of P25 stations using Audacity and can see the NAC code being transmitted. I should actually say NAC codes as some transmit several NAC codes at the beginning of their transmissions. Most software only sees the first one.
Marcy57
possibly? just talk abt Watch Hill both stations...
dave3825
Suffolk County NY
So you see 4f9 talking to 68f? I threw that freq in dsdplus over night and received nothing until this morning. I didn't see how strong it was
2022/07/09 03:08:10 Freq=166.300000 Group call; RID=33599
2022/07/09 09:01:12 Freq=166.300000 NAC=4F9 Group call; TG=1 RID=1 [?] Pri0 2s
2022/07/09 09:01:20 Freq=166.300000 NAC=4F9 Group call; TG=1 RID=1 [?] Pri0 3s
How do you achieve this? Are you running a recorded transmission thru or doing it live?
Marcy57
Yes Dave it,s Fire Is. ...which is close to us it was vy strong S9
lots of activity with the nice wx, usual Parks stuff "out of service"
"going to Watch Hill" etc. yes 4F9 to 68F ...Marcy
ecps92
Taxachusetts
a radio is generally only transmitting "A" NAC Code, yes they can have programmed Multiple NACs to use, but will only Transmit One per transmission.
dave3825
Suffolk County NY
I have 171.625 as fire island and when the key up it wipes me out. Saw signal just now on 166.300 and it was maybe for me a 6 to 7 and did not look centered on the spectrum.
Marcy57
Was using 400 mhz yagi pointed south/southwest not the Discone and it was S8/9
but the Sridsberg is hooked up to it and the preamp in the 8600, no 68F copied
today just 4F9...so far...Marcy
ecps92
Taxachusetts
Thinking (just a WAG) either an adj RF hit +/- or a nice DX for the $68F
See what you get overnight :)
Marcy57
Just now I got 68F agn communicating with 4F9 asking for info
....so it,s not dx or a Wag as u call it...73,s Marcy
Marcy57
Seems from monitoring like ? the mobile units are 68F too me I don,t know
guessing??...or one of them anyhow??..Marcy
Marcy57
Now I gotta see 166.2875 whats up with that one? and where??...Marcy
