1999 Lumina radio setup
phillydjdan
My 1999 Chevy Lumina radio setup:
UHF Motorola MCS-2000 Model 2
VHF Motorola MCS-2000 Model 2
Pro-96 handheld scanner
Dual-band antenna
The UHF and VHF radios are connected to the dual-band antenna through a duplexer.
The portable scanner is mounted to the dash by a custom bracket made from scrap pieces of metal banding material. The plastic belt clip has also been replaced by a custom metal clip made from scrap banding too.
Rt169Radio
CT
Looks good.Do you keep the Pro-96 in the car all the time? Or do you just put it there when your not carrying it around?
phillydjdan
The 96 stays in there most of the time. I do hide it when I'm not around to avoid theft. I use it mostly when in the car and when I'm out of the car somewhere. I have a PSR-800 in the house, so no need to bring the 96 inside.
Rt169Radio
CT
How does it (Pro-96) receive in the car with that handheld antenna?
phillydjdan
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.2.3; en-us; SPH-M910 Build/FROYO) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
Well, I use it mostly for Philly fire, and I live in the city, so reception is more than adaquate. In fact, I leave the attenuator on most of the time, otherwise the digital cuts in and out. If I'm looking to pickup the surrounding counties I can do so relyably if I'm within 8 or 10 miles of the border. The other 2 radios are for the surrounding areas, which are full analog or digital rebroadcasts on analog channels
Skypilot007
Medford, NJ
Nice job on the install. Looks good, nice and neat. MCS2000's are great radios.
62Truck
Ordinary Subscriber
Uranus
Nice set up! I miss my Lumina
phillydjdan
Yeah, so far I like the MCS-2000's. I lucked out and found a couple sellers on fleabay that had conventional ones with no issues. I have a thread on here where I asked a bunch of questions about them before I bought one. I actually just finished setting up a pair of them in the home shack as well. I didn't think I could do it, but I have all 160 channels occupied :)
phillydjdan
UPDATED setup
So, I've done some updating in my car. I got rid of the MCS-2000's in favor of Kenwood NX series radios (UHF and VHF). In order to mount them in a way that I can easily reach them, yet not have them shake on every bump, I decided to get a little creative. I went the the junkyard and pulled a center console out of a Chevy Monte Carlo of similar year. I then chopped off the front portion, right in front of the gear shifter, and mounted it in place. The cassette/CD holder makes a perfect place to mount a radio, or in my case, 2 radios stacked on top of each other. The NX series fit snugly, but I managed to make it work. I had to punch out the back of the cubby hole, to make room for the antenna connectors. Both feed into a duplexer and a dual band NMO mounted on the left rear quarter panel.
I threw in a couple of pics of the home brew mount I use for the Pro-96. I made it out of a piece of banding material.
I still have VHF and UHF MCS-2000's setup in my home shack.
russellmaher
KC1ANC
Enfield, CT
Good looking install! I loved my 97 Lumina (it's gone now) for the lots of space for putting scanners and other gear. I'm guessing you're enjoying yours.
Russell
