19xs no squelch
James6600
Indiana
Hi all. I have a Cobra 19xs that I’m troubleshooting for a no squelch problem. ( squelch does not silent ). I have checked the circuit from the potentiometer up to the IC circuit amplifier according to the block diagram. I have not checked the IC yet. Is the block diagram accurate enough to cover all components. I checked the potentiometer, q107 and q106 and they are good. Am I correct in assuming the IC is bad since that’s the last thing before the speaker in the block diagram? Will the IC cause this problem? Thanks
James6600
Indiana
Let me rephrase this question. I’m new at this as you can tell, this is my first radio when I was a teenager in the 80’s and my work radio for many years so I want to fix it. I know it’s not worth it. I have checked the resistors and transistor between the squelch and the I/C audio amp chip. All checked good and voltage was correct. So my first question is, if my voltage is correct at the I/C input from the squelch can I assume the two capacitors that run to ground in that part of the circuit are good/ or good enough not to cause the problem. I plan on recapping it once I find the problem. Thanks
