If you have already downloaded and installed the EZ Scan application from the whistlergroup.com website
as of 2/6/18, please update to the latest release using the pc app > Check for PC Application Updates.
This will address many of the compatibility issues of the newly complied application with Win 10
If you have not downloaded and installed the EZ Scan application from the whistlergroup.com website
as of 2/6/18, please download and install by going to www.whistlergroup.com/pages/downloads
Once you have installed, please check for update using the pc app > Check for PC Application Updates.
New with this release:
Resolved inconsistent font sizes in various lists.
Fixed scanlist listing on the general tab to remove the horizontal scroll bar.
Possible fix to extra characters being added to alpha tags when adding talkgroup and radio ID objects to a trunked system.
Updated the processing when deleting a talkgroup or radio ID object in the trunked systems tab to update what's happening during the process.
Removed the resize restriction. Lists that are resize-able will now expand based on the screen size as they did in prior versions.
The interruption and the issues that followed are the result of an unexpected security level change causing us to use a new compiler that supports the new security levels, With the new compiler there were a lot of changes in the language resulting in functions and syntax used either no longer exist, or have changed.
We will continue to address issues when they are identified and appreciate everyone’s patience and understanding.
Bug reports should include the EZ scan version, PC operating system, and a description or screenshot of the issue.
Again, thank you for your patience and understanding.
Whistler Wendy
Whistler Wendy
