K9DWB
Yep and thanks to both. I'll say this, prcguy, you know what you're talking about. The tripod you suggested is excellent for this type use. I will note if I want to collapse the extended mast, that air charge resists a bit, but it does make it very easy to extend. I'm going to put the Neewer bags on the list. I'll probably go with rocks for the weight as I can't find my sand castle shovel from years ago. OK seriously, I think for me rocks may be easier to do than shoveling sand.
And I'll be spot spraying the antenna with a few other colors to hide it a bit better. The odd choice of matte hunter green actually isn't bad where the antenna is now, but I'd like to break it up a bit and add a few splashes of other colors. I found that Lowe's has some camo labeled spray paints that I'll take a look at in a few days after SSDI monthly hits the account.
