If you have a recent Uniden scanner most models have two-tone ("Fire Toneout") on them. If you set the two tones to 0.0 Hz. the radio will go into Search mode and display the decoded tones when detected. They are usually accurate to within a Hz. or so, close enough to be reliably decoded as such when programmed.
