2 tone Paging Tone decoder
Brettame5
Does anyone have a free software that can determine what Mgz tones are for 2 tone paging?
nated1992
Asheville NC
Hey im developing a program that will run station alerting systems. As part of it i tested with a online pitch decoder. It doesn't log them but it will show the MHZ of tone codes. it can be found here Pitch Detector
Past that I am about to publicly release my program for use and can do a version for you that would log tone codes. Message me.
N9JIG
Sheriff
Moderator
Far NW Valley
If you have a recent Uniden scanner most models have two-tone ("Fire Toneout") on them. If you set the two tones to 0.0 Hz. the radio will go into Search mode and display the decoded tones when detected. They are usually accurate to within a Hz. or so, close enough to be reliably decoded as such when programmed.
dave3825
Suffolk County NY
nated1992
Asheville NC
Those tones would be Hz (Hertz).
It would be nice if that had an input selection for live instead of just a mic.
Do you have a public download link for your program?
I do believe you are right Hz is what that script reads. And it has to be converted to Mhz.
I was just playing with understand how the math works to understand the tone audio for that application by live what do you mean? Audio feom Mic input would be live audio ?!
I have not released it publicly yet.
