2000 NBS Silverado Install
KI5IRE
Dallas-Fort Worth, TX
I have a 2000 NBS Silverado I am looking to install a mobile VFH/UHF setup into. Anyone here ever set one up?
Hoping to try to find a Yaesu FTM-100D or similar, but don't know where to mount the radio or antenna or run the cabling. Any suggestions or pictures of installs would be much appreciated.
NBS?
If you can post a photo of the interior, that would help joggle my memory. I know I've done installs on trucks in that era, but I'll be danged if I can recall without some reminders.
KK6ZTE
California
NBS?
The early 1.5 din version
OP, do you have a center console?
KI5IRE
NBS?
NBS is short for "New Body Style", its just another way to say the 2000-2006 era of the GM trucks.
KI5IRE
yes, it's the 1.5 din. I think I'm going to get one of the seatbolt mounts for the RH to mount the radio itself in the truck. I'm mainly trying to figure out how to run the cabling, power the radio and antenna mounting locations. I've thought a bout possibly doing a lip mount in the bed of the truck.
KK6ZTE
California
I've got an 03 2500HD with three rear mount radios (KW NX-5700/5800 VHF/UHF and KW TK-690). All three decks are mounted behind the rear seat on the little "seat follower" hinged pieces (Crew Cab) with an 8awg positive wire ran down the channel along the driver side, exiting the cab into the engine compartment via the large grommet above the MBEC. Ground is via the factory ground point behind the passenger C-pillar.
Two roof mount nmo antennas, VHF and UHF.
I'll post some pictures later once my wife is done using her truck.
OK, that helps, I figured that's what you meant.
So, looking at google for interior photos, that kicked the fog out of that corner of my brain.
Did some installs on those, but they all had the center console. The trucks didn't have the cassette deck down low on the dash, so there was a nice little empty pocket there. I do recall the Icom commercial radios fit very nicely in that spot. I think Icom IC-F621 was what we put in there. Worked out very well.
As always, power direct off the battery. At the time we didn't run these with ignition sense, so not sure where to pull that circuit from on those trucks. Not sure if there was a dedicated feed like the newer models. There's a big grommet under the hood leading in under the dash that we were able to route through.
Coax was routed back around the dash, under that, and up to the roof for a single 1/4 wave UHF whip dead center on the roof. I seem to recall we were able to install them above the dome light to make cable routing a bit easier.
