2005-2008 VIPER Discussion (Archive)
justin302
creston,nc
i work in watauga county i do know that the sheriffs dept wants to switch to the viper system but they have to put up atleast 5 to 6 towers because of the mountain terrain. i do know that when they do switch over they deputies will keep the old 150 mhz radios in there car to keep in contact with blowing rock pd, boone pd etc. and the little depts probably wont switch over to that system for a long time.
SGT. Wood
Blowig Rock pd
rescue161
KE4FHH
Hubert, NC
I-Call Control Channel Data?
Been listening to the Onslow County-Holly Ridge tower (Site 118) and hear CC data on 708136. Does anyone know what this is used for?
KE4ZNR
Radio Geek
Check your programming bro...708136 is a RID (Radio ID) not a Talkgroup ID (TGID). What type of radio are you using? Could just be bleedover...try disabling Icalls....or just lockout that one individual RID.
Marshall KE4ZNR
rescue161
KE4FHH
Hubert, NC
Marshall KE4ZNR
It kept popping up when in search mode, so I had to lock it out. My 396 and 996 pick it up just fine. Haven't tried it on the Pro-96 yet.
KE4ZNR
Radio Geek
Don't worry about even trying the Pro 96 as that scanner is incapable of monitoring ICalls or RIDs. An Icall (or private call) is 2 radios contacting each other away from a regular talkgroup. the 396/996 display these as RID RID. Example: 708136 705135 which would be Radio User 708136 trying to contact Radio User 705135. I promise you what you have there is bleedover. Meaning that you should not be hearing the CC on that RID. So just lockout that individual RID and enjoy monitoring all of the other action on the radio :)
Marshall KE4ZNR
rescue161
KE4FHH
Hubert, NC
Marshall KE4ZNR
Cool, thanks man. Thought I was going crazy there for a while.
kd8x
NC
I have copied these VIPER id's and don't see them listed in data base....Anyone know who they are?????
41744
42736
42288
36496
34384
32784
176
496
80
48
I havn't a clue???
kd8x
NC
Mooresville TRS?
I havn't been able to decode Mooresville for the past couple of days even though I do have a good signal on them on the CC....Anyone else having a problem with Mooresville??
FireCop
Public Safety Grunt
Statesville, NC
kd8x are you talking about the Mooresville VIPER site or the Mooresville TRS? I know my XTS 2500 worked fine on the city TRS the last few days. :)
kd8x
NC
Im talking about the Mooresville TRS not Viper....I cant get it to decode yesterday or today...When I listen to the CC frequency somthing just doesn't sound quite right ie it is not the usual machine gun sound....It sounds like it is almost off frequency or fading in and out....
reconrider8
Eastern, NC
yea on the fading in and out how can you stop that? cause i can be hearing hp and it will fade in where its clear and then like 1/2 a sec later you cant understand it?
KE4ZNR
Radio Geek
Two options:
1) Move closer to the closest tower site
or
2) Use a better antenna.
Thats pretty much your options.
Marshall KE4ZNR
reconrider8
Eastern, NC
im thinking bout getting the radio shack vhf/uhf antenna cant beat the price think it will help much... planning on putting it in my attic
reconrider8
Eastern, NC
another ? is like i have my scanner programed right but when its scanning sometimes it will jsut land on the cc(868.8500) just like in regular scanning and all i hear is the like data channel just a bunch of rumbleing
KE4ZNR
Radio Geek
Check your programming. Sounds like that 868.850 is probably incorrectly programmed in as Conventional FM instead of Motorola as it should be. Remind me of which model of scanner you are using?
Marshall KE4ZNR
