I've always preferred dedicated antennas for each band. Diplexers add a bit of loss, plus extra connections. Put a 1/4 wave VHF and a 1/4 wave UHF up there and it would be pretty low profile and work well. If you don't have a sun roof, you've got plenty of real estate up there.
If you don't plan on using the CB that much, then put it up on the roof also. When you are not using it, just remove it and put an NMO rain cap over it. Would look a lot cleaner, in my opinion, then having a bracket NMO sticking off the hood.
While I was at it, I'd stick the scanner antenna up there also. You've got plenty of room, and you'll be routing cable anyway. It's much easier to route the coax from a permanent mount than from an exterior mount, under the truck and back up into the cab. Plus, you'd have to go with a well sealed NMO mount, like the NMO-HF's with good sealing if the underside is going to be exposed to the environment. Most NMO mounts are designed to be installed through the roof and the underside where the coax is connected well protected from the elements.
Anyway, the antenna will be happier with a ground plane under it.
