tscroggins
- Joined
- Apr 4, 2022
- Messages
- 4
Apologies in advance if this is a long winded post but I’m looking to get clarification on some things as I’m not a professional upfitter. I have a 2019 Ford Police Interceptor Utility and I installed a XPR5550, however it’s not hooked up to power yet. I plan on installing a APX8500 at a later date. The vehicle has a 6 way power feed harness with 3 hot wires rated for 34 amps each and 3 ground wires.
What I would like to know is, can I wire both radios to 1 hot wire or should I dedicate 1 hot wire per radio? According to the APX cut sheet, the transmit current @ 100 watts is 30 amps and the receive current is 3.2 amps. For the XPR the transmit current is 40 watts @ 14.5 amps and receive at 2 amps. Just want to make sure I do it right cause I’d rather my car not burn to the ground lol.
