2025 F-150 Remote Head Options
tweiss3
Is it time for Coffee?
Ohio
Just bought a 2025 XLT for the wife this weekend. Traded from a Transit Connect, which came from the factory with a huge overhead shelf I was able to mount a radio head to. I'm sorta at a loss on mounting the Kenwood KCH-20 remote head. I see Troy Products makes the CC-21F1-OH 7" overhead console, but I haven't seen any installed photos, and I'm wondering about the integration of the lights and rear power window switch, as well as how it looks. There aren't many other places to put the control head. Any other product options besides Troy?
I thought I had a photo, but apparently I don't. It looks like this stock photo, except the space in front of the cup holders doesn't have the sliding cover, that is where the wireless charging pad is, and I'm 99.99% sure the wife really likes that feature, so access to it is required.
I thought about above the screen on the dash, there is a little spot to place something, but it would be in direct view and sun all the time, so I'm trying to avoid that. The radios were hidden in the Transit Connect, except for the roof antennas, so I'm hoping to find a solution that is reasonably hidden at first view from outside.
Any overhead photos would be appreciated as well.
jeepsandradios
East of the Mississippi
Can you put the head in the center console. Do that for multiple SAR folks that just need to talk or listen. Is it critical to see the head ?
Those higher trim levels make it difficult.
Top of the dash is less than ideal, but can work in some parts of the country. I've got transit buses with Kenwood radios mounted on top of the dash and they've been fine, but I'm in a cooler climate than Ohio.
I agree with above, inside the center console would be my choice on that vehicle. We do that with our unmarked/take home vehicles and it works fine if you don't need to be diddling with the controls all the time.
Or, go with the hand held control head….
tweiss3
Ohio
That is a possibility, I'd like to be able to glance at it when I'm scanning to see what actually is being received. Otherwise, its swap zone at each state boarder and leave scan on. It would allow the mounting of the SDS200 as well, which I haven't even come up with ANY solution yet.
That's the thing, its an XLT, not even a premium trim level. Reasonable access? yes. often? No. Honestly most of the time its on/off via ignition sense, set on the home channel with the second deck muted and she just grabs the mic.
HHCH (KCH-21) is an option, I'll have to see if I can find one for sale, brand new that's expensive, but I would swap her 20 for my 19 and get an upgrade in my truck.
BTW, shopping for new cars, holy crap, there is a lot of offerings that couldn't even have been imagined 10 years ago when we last bought her a car.
EDIT: Now that I think more than 10 seconds, I left the KCT71 cable in the old car, so I have to either buy one, or the KCH21 would be $200 bucks less in the scheme of things.
Sorry, relatively to me. I've got a 2025 F250 XL with the bench seats, so I just stuck the control head under the dash.
My brother in law just got a 2025 F150 and I briefly looked at where to mount a radio in that, and it was going to be difficult.
In the center console seems like the easy option. Like I said, lots of our take home cars are set up that way and it works well enough, but her needs may vary.
Yeah, dealer was astounded I wanted a stripped down XL trim level. The options now are amazing.
Nice truck you guys bought. I really like those.
Not sure how much room there is between the shifter and the cup holders. Can you sneak it in there, sideways? Did that once with a 2009 Escape and it worked well, but no cupholders to block.
Other than that, taking over her charger pad would be the easy option.
Top of the dash can work if it's out of the way of airbags. I've got an F350 at work set up like that. Not my favorite install, but it's worked fine for about 3 years now.
tweiss3
Ohio
He's probably in the identical situation. Yea, its way tougher than I thought it was going to be initially. Wife insisted on a few frills, so that added a bunch of stuff I probably wouldn't have chosen.
Not enough space, it looks like a lot until you set the backet there.
Related question, now that I'm ordering more NMO mounts for this new install. I'm guessing I should avoid the brass NMO mounts (galvanic corrosion on aluminum body), right?
Not an issue if installed per manufacturer recommendations. For galvanic corrosion, you need an electrolyte, and that would be water. A properly installed NMO mount with the gaskets and O-rings will not let water get anywhere that this can happen.
I've got brass NMO mounts on lots of Ford trucks at work and have not had any issues, and I'm very close to the Pacific Ocean with lots of fog/rain.
jeepsandradios
As @mmckenna said if they are installed properly you will have no issues. We have been installing in aluminum for years. My F150 has 6 NMO mounts (all MSI brass mounts) and have had no issues in 5 years. Mine have been all over the NE with no issues.
So, I know you know this, but for the others that wander into this thread with concerns about permanent NMO mounts on aluminum body trucks:
I just swapped out one of the antennas on my work truck. This is a 2017 F350, NMO mounts were installed when the truck was brand new. Truck lives full time within a few miles of the ocean and a few times has been hit with spray directly. These antennas have hit a lot of tree branches, also, never once damage to the roof or NMO mount.
No issues in 8 years. I owe this to:
-Following installation instructions
-Using the correct tools
-Using the correct gaskets and O-rings
-Periodically removing the antenna and cleaning under it and checking gaskets, replacing if they look damaged.
-I periodically wipe down the gaskets with Armor-All and that keeps them in good shape.
Just like the rest of the vehicle, periodic maintenance is important to longevity. Ignore it and it will bite you in the ass.
cavmedic
Pottstown Pa
I'd just use the spot for the wireless charger and find a better aftermarket one to use. If using an apple, you can get a magsafe charger that works better than most factory installed wireless chargers, and they make ram mounts for them . Not sure about android stuff
ramal121
Lots and lots of watts
Calif Whine Country
Can you get a photo of the side of the console? If it has the indented junk pockets you can mount a head there and angled up to the driver.
Now I just hate to install anything to the left of the console, but a KCH-20/21 tucks away nicely without being in the way. Drill a 1/2 hole where you can't see it for a cable exit into the console.
ofd8001
Louisville, KY
You may want to look at: Bulletpoint Mounting Solutions for Jeep, RAM, Ford, Chevy, GMC, Toyota
I just installed one in my 2020 F150. it was for an iPhone charger, but there is plenty of room left for other things to be mounted. Unfortunately it is visible and thus a thievery temptation.
If yours is like mine, there is a storage tray/USB access area at the front of the console.
I've got my radios in the console itself (VHF, SDS 200 scanner and a Motorola XT). It is a pain to access for volume control, channel changing, but not the end of the world.
KF0NYL
Consider LIDO Seatbolt Mount.
Several optioms.
My 2023 Ford Escape ST-Line has even less room than a F150. I went with a LIDO seat bolt mount and it has worked fine for me. I ended up getting another LIDO mount for my 2010 F150.
I have a Buletpoint mount in my 2010 F150 but I only have a phone holder and a hand held radio holder mounted to it. Anything else would be above the dash and blocking my view. Plus I don't like having radios in direct sunlight all of the time. Vehicles get pretty warm in the summer here in Missouri. The southwest would be even worse.
tweiss3
Ohio
I have spare gaskets sitting around, they all got replaced at the 3 year mark, that's when they seemed to start drying out on the outside.
There is a pocket, but it's so far down, seeing around knees would be worse than dealing with tucking it in the center console.
Several optioms.
I have that in my truck, the heavy duty version. I like it, but you still have to target the head somewhere. There isn't really a space out of the way.
I did bookmark the bulletpoint system for later, thinking if I did do a dash mount, that would be the foundation.
I did grab some photos this morning, they are a bit dark this time of year. She has "moved in" already....
Inside console seems good for the SDS200, but really cumbersome for the remote head.
Lido seat mount would be in passengers knee room.
This would be her view over the dash, head would get in the way.
Not really decent room on the drives side of the console.
Close up view of that front pocket.
Not enough room between the shifter and cup holders. Head does get in the way of both.
So, I talked to her this morning. Took the KCH-20 head and bracket out with us to the truck. The charging pocket was immediately rejected, though it did fit nicely in there. Between shifter and cupholders did not work. Over the dash would be tolerated. I then mentioned the HHCH below the push-to-start and she jumped on that. In thinking about it, that is the ideal solution. I don't have to deal with routing/mounting the primary KES5 speaker. Previously it was right over the drivers head, but hidden. To be similarly pointed, it would be in the way. I'm not fighting the extra money needed, because she isn't pushing back on the radio install.
This also means I can step up from KCH19 to the KCH20 in my truck. Win on both.
Well, damn, that's about the best scenario possible.
tweiss3
Ohio
Thanks for the photo, even if it is a non-negotiable option for the wife.
So, HHCH came in (thanks Evans), as well as all the NMO mounts and I was trying to get to starting the install yesterday afternoon. Unfortunately I couldn't find my NMO hole saw, it's hard to keep track of something that small that is used maybe once every 3-5 years. This lead to me working on cleaning my home office (this is a disaster because things just get tossed in there by others), and I wasted all the daylight on that project. Fortunately, I found the hole saw, but also the GPS/BT board that was fried in the VHF head. I replaced that board, and found the shield doesn't come with it, so I had to transfer the shielding from old to new.
OLD board:
New installed, minus shielding:
I did do some more poking around and reading about the truck. I think I found a good source for ignition sense. I also learned about the BMS in these trucks, and that I have an auxiliary battery under the rear seat. Though it would be right next to the soon to be installed remote RF decks, I won't be connecting power there, the battery is tiny and is known to have problems, I don't want to add to that.
Maybe this coming weekend I will have time to get things installed.
tweiss3
Ohio
This weekend was try to get things done before I'm stuck dealing with snow. It ended up just this truck got work, 7 hours Saturday and 6 Sunday, but going slow and doing it correctly is important.
First things first, holes in the roof. I put the scanner antenna center, 20" from the rear, then the other two ended up 26" in front of that to avoid a reinforcement rib, 20" apart and 19" from the sides of the roof.
Next, 4AWG SAE wire was run from the battery to a breaker 6" away, then through the firewall to under the rear seats. Ground was run to one of the common ground points on the back of the cab. I then mounted everything on a 9" x 24" plywood backer. I also decided on this one to run a ignition sense bus, fusing each connection. I ran out of time and daylight to connect the bus to anything.
Dropped in place it looks good under the seat.
Next, the SDS200 went in the center console, with an external speaker (KES3) on the passenger side of the center console. Now its nice and loud.
Lastly, the unselected deck speaker is on the drivers side of the center console, and the HHCH is mounted on the dash.
I'm happy how it turned out, but it took a long time. Wife is happy with it too, but came out at the wrong time when dash and center console panels were removed and laid out in the bed. The 1W output seems loud enough only mildly turned up, and I don't seem to have any RFI issues coming from the car, even though it is the Powerboost Hybrid. Even with just my HT the past 2 weeks, both VHF and UHF were receiving with no issues.
Now to hope that I can find a decent place to get Ignition Sense hooked up. It appears modules changed, so the place I thought I could use isn't a good spot anymore.
Looks good.
Not sure about the F-150, but the F-250/350/etc. have a tapped off 5 amp ignition switched feed behind the passenger side kick plate.
Might want to check here:
