2026 Indycar
evilbrad
My head makes a bad antenna
Anyone going?Or should I say going this weekend?
ccsprague
Alachua County, Florida
Just loaded it into Sentinel via CSV as the bearcat files aren't interchangeable. I'll be in the pits this weekend so I'll try to report back any issues. I'd share my .hpe file but its not an allowed file format on the forum.
evilbrad
Currious if you own the re3000. Truck pdf was put online. I'm interested Since this is one of these split race weekend deals If the ota is working and if it is online 450/or 460 they may have indy freqs available via re3000/4000 ota. I do know most split races the team scanner isnt a option to listen remotely.
ccsprague
Currious if you own the re3000. Truck pdf was put online. I'm interested Since this is one of these split race weekend deals If the ota is working and if it is online 450/or 460 they may have indy freqs available via re3000/4000 ota. I do know most split races the team scanner isnt an option to listen remotely.
I don’t. I use the SDS100. I doubt they are there doing OTA as they listed manual programming on REs website and no retail activity.
evilbrad
The split events where there is no retail is hit and miss. Few times was told there was others nada. Occasionally you will get a ota setup by whoever is doing the team/series setup though some times I had to walk near pit.
Here are the up-to-date Scanner Frequencies for INDYCAR and IndyNXT updated at St. Pete including almost all of the DCS tones. As always many stayed the same but there were several new ones including Arrow McClaren getting all new frequencies entirely. Here is the file for Bearcat 125AT Scanner as well.
INDYCAR Team Frequencies
DriverCar #Primary Freq (MHz)Primary Tone/DCSSecondary Freq (MHz)Secondary Tone/DCS
Josef Newgarden2464.925DCS 271469.6Off
Scott McLaughlin3466.825DCS 223464.675DCS 223
Caio Collet4463.0125DCS 465467.6875DCS 546
Pato O'Ward5460.5625DCS 152469.4375DCS 152
Nolan Siegel6460.6625DCS 431462.7875DCS 431
Christian Lundgaard7460.7625DCS 464464.4625DCS 205
Kyffin Simpson8457.025DCS 516461.1125DCS 364
Scott Dixon9456.65DCS 125461.1875CTCSS 167.9
Alex Palou10467.0375DCS 036464.0375DCS 043
David Malukas12466.2125DCS 371464.6DCS 445
Santino Ferrucci14467.075DCS 411458.9125DCS 205
Graham Rahal15466.9125DCS 565468.8875DCS 431
Romain Grosjean18467.2DCS 132469.9375Srch
Dennis Hauger19463.6DCS 162464.9375DCS 125
Alexander Rossi20469.1125DCS 734457.675DCS 532
Christian Rasmussen21469.925DCS 466465.9625DCS 351
Will Power26464.3DCS 026463.2125Srch
Kyle Kirkwood27468.4875DCS 025467.8875Srch
Marcus Ericsson28469.3DCS 115469.75Srch
Louis Foster45466.3125DCS 031467.8375DCS 261
Mick Schumacher47469.2625DCS 712468.2625Srch
Felix Rosenqvist60461.075DCS 143454.5DCS 631
Marcus Armstrong66452.8DCS 261461.725Off
Rinus VeeKay76458.1DCS 612455.15DCS 223
Sting Ray Robb77459.65DCS 627454.65Off
IndyNXT Team Frequencies
DriverCar #Freq (MHz)Tone/DCS
Nicholas Monteiro4460.8DCS 226
James Roe8466.1125DCS 631
Bryce Aron9452.7DCS 051
Niels Koolen10466.1DCS 072
Carson Etter11466.375DCS 754
Max Garcia12463.775Srch
Alessandro de Tullio14460.9DCS 074
Nicolas Stati15460.0125DCS 114
Salvador de Alba17460.1DCS 306
Matteo Nannini20453.4125CTCSS 103.5
Nikita Johnson21463.1625DCS 311
Lochie Hughes16469.5375DCS 606
Seb Murray27464.5375DCS 612
Max Taylor28462.9125DCS 343
Josh Pierson29469.8375DCS 271
Jack Beeton45460.2DCS 132
Jordan Missig48454.7875DCS 152
Colin Kaminsky57467.1625DCS 065
Enzo Fittipaldi67460.3DCS 445
JM Correa68460.6125DCS 071
Tymek Kucharczyk71460.4Srch
Alexander Koreiba75462.0125Srch
Ricardo Escotto46464.0125DCS 172
Myles Rowe99467.2375DCS 664
Race Control/TV/Radio
ChannelFreq (MHz)Tone/DCS
Race Control 1468.825CTCSS 103.5
Race Control 2467.0125DCS 032
PA450.725
Radio450.75
Radio2454.7
FOX450.6
evilbrad
evilbrad
Anything for the the other series (non nxt and Indy car)
ratpatrol
Toronto, Ontario, Canada
PA450.725
Radio450.75
Radio2454.7
FOX450.6
Thank You
Honda Indy is moving from the Toronto waterfront circuit due to FIFA Soccer Madness to Markham city streets. This will be a first for many drivers and hopes they put together a proper event. Transit will be a huge issue
evilbrad
Indycarfreq.com has some new updates
llarsw
Anyone know if it's possible with a BCD325P2 (or a BC125AT) to actively monitor one frequency while also scanning in the background? My thought process is to stay locked on the PA frequency but leave the driver frequencies in scan mode so it stays on the PA frequency unless one of the driver channels becomes active, then switches back?
AK9R
Staff member
Super Moderator
Central Indiana
There are very few scanners that will scan "in the background" while monitoring a frequency. There are some dual-band amateur radios that have two actual receivers that might do what you ask.
cubn
Search, Listen and Submit
Marion/Johnson County, IN
Sounds like the Priority channel setting might work?
But then you'd have the PA being interrupted every few seconds as it checks for activity on the priority channel.
AK9R
Staff member
Super Moderator
Central Indiana
Harold
Texas
From the web page that you linked to with my underline for emphasis:
"For Professional Racer Use Only - Does not scan and meets series requirements of not scanning between channels."
Wow, keen observation. The op wants to remain on 1 channel (PA) so that does not need to scan. Program that into the Receiver-Pro and feed the Scanner with driver freqs though the Receiver-Pro. It has the ability to pass though the drivers audio as well as the PA audio.
I do it at every Nascar race I attend. With the exceptions that I listen to Race Control on the Receiver Pro and I use and ear bud in one ear and feed Drivers to a some Wired Shokzs and a earplug in the other ear. Works every time.
AK9R
Staff member
Super Moderator
Central Indiana
You are proposing adding this single-channel receiver, and an interconnecting cable, to the mix. But that doesn't answer the OP's question, which was:
If the OP can accept using additional devices to accomplish his goal, you're solution would work.
