325P2 QUICK KEYS
kf6mxk
Tehachapi,CA
I have a 325p2 and a 436 . I can use all 99 QK on the 436 from the keyboard. On the 325 I can only access the 0-9 QK from the keyboard. I want to be able to drive and punch in the numbers 0-99 to change the QK on the 325.
kf6mxk
Tehachapi,CA
Thank you . The ARC XT program has 0-99 QK and that's what confused me.
hiegtx
Dallas, TX
You can use QKs 0 to 99 for systems or sites. But the groups on the DMA scanners such as the 325P2 are limited to 0 through 9, and a maximum of 20 groups allowed per system.. The software may not be telling you the exact error if trying to use a QK higher than 9. Of course, on the x36HP & SDS series scanners, Departments and Sites share a set of 0-99 QK's, with Systems & Favorites lists each using a 0 to 99 universe of quick keys.
dispatch235
Central Missouri
To access a system or site with a 2 digit number you hit the decimal key, then the two digits to turn them on or off. Example if you want to turn on the quick key 21 you would key in .21
