Quick Keys Programming Question 325P2/996P2
rs16
Question about assigning Quick Keys for a 996P2 using ProScan. I have 1 conventional system (System Quick Key 1) with two groups. I'd like to make the Niagara Frontier Transit Authority System 2 so I can turn it off if not interested. It is a simulcast system which consists of 10 Bus talkgroups. Do I need to assign a Quick Key to the Bus talkgroups? Or would turning off System 2 QK turn off the whole thing so I could just monitor police/fire (System 1)
hiegtx
Dallas, TX
If the buses are the only thing in your 'System 2", then you could assign a quick key to the system and use that to toggle it on or off. (Since Niagara Frontier is a trunked system, you would not have a "system" quick key. Instead, you set the quick key for the site.) However, I see that there are police talkgroups as well, on that system. Apparently those may be dedicated to he bus & rail systems, not general law enforcement. But if you wanted to leave them active, but 'turn off; the bus TGIDs, then you'd need to do that at the group level. Put the bus TGIDs in a group, with the police related talkgroups in a second group. If you wanted to break down farther, put rail related TGIDs in a third group.
You can then use the group quick keys to focus on whichever portion of the system that you wanted to monitor.
This Wiki page will help you understand how to use quick keys to customize your listening.
For conventional systems, you can set a system quick key, then also assign group quick keys if so desired.
rs16
Thanks for the detailed response which I read several times. Still kind of confused...I just want the Busses (not interested in Metro Police).
1. Did I do this correctly below?
2. Will the scanner still be trying to scan those frequencies listed under Simulcast if the Bus group is off? Or do I have to assign a Group Quick Key to Simulcast (and turn that off when not interested), Thus turning off Simulcast and Bus when not interested in Busses.
hiegtx
Dallas, TX
If you did not program the law enforcement, rail, nor any other set if talkgroups using that site, the scanner would still, though only briefly, try to monitor that site, before moving on to the next active system (trunked or conventional) that you have programmed & is not set as locked out.
If the only talkgroups that interest you on that system are the buses, you could marginally speed up your scanning by setting, and using, a quick key assigned to the site, not the group, to toggle that set of talkgroups on or off. If, instead, you assign a quick key to the Simulcast site, then you can toggle that system on or off using the Site (in lieu of System) quick key. (System keys cannot be assigned on trunked systems. The key is assigned at the site level. For a system that only has one site, as is the case here, toggling the site on or off, adds, or removes, the system from scanning.)
I would note that in your case, using the Site key, it's somewhat easier to toggle that system on or off. You can simply use the quick keys number. If using, instead, a Group quick key, you have to preface that by pressing Function while monitoring the system.
(Side note: I spent over a dozen years maintaining buses used at DFW Airport for car rental customers.)
rs16
I appreciate your generous efforts, but I must be dense. I thought that is what I had originally. Just trying to only scan the busses. Is this right below?
hiegtx
Dallas, TX
View attachment 199881View attachment 199880
Since this is a trunked system, with only the single site, and you only have one group programmed, which is for the Metro Bus talkgroups, toggling that site quick key on or off will let you turn them on or off as desired. There is no need to also program a group quick key. Had you also added law enforcement, and/or another department in a separate group, then a group quick key might have been useful, For what you are programming, only a single group, then turning the site on or off accomplishes what you want,
rs16
Thank you so much for explaining it.
