BCD325P2/BCD996P2: 325p2 trunking question
firebell9137
bearcatrp
Land of 10,000 taxes
Not when there is only 1 tower to deal with. What antenna are you using? If it’s the one that came with the scanner, then that’s the problem. Hook it up to an outdoor antenna and you should be able to hear it.
dmfalk
Another thing to think of: are you still using the stock antenna it came with? (Lots of better antennas out there....)
firebell9137
Im using the Remtronix 842b.
hiegtx
Dallas, TX
What do you mean?
For a more complete description of simulcast distortion, it’s affects, and some countermeasures that might (or might not) help, see the Simulcast Distortion page in the Wiki.
Basically, in a simulcast site, you have multiple transmit towers, sub-sites, all transmitting the exact same radio traffic, on the same frequency, at the same time. While radio waves move at the speed of light, these signals, coming from more than one location, at various distances, arrive at your scanner at slightly different times. While that is a very tiny time difference, they are out of sync enough to impact the scanner’s ability to correctly monitor the system. So, you might either hear nothing, or the scanner is so “confused” that all you hear is a garbled mess of audio, nothing that can be understood.
With a “better” antenna, you’re getting signals from most, if not all, of these subsites. With “less” (or a worse, less effective, antenna) you might eliminate some of the more distant, weaker, signals, letting the closest, stronger, signal override the weaker ones, giving the scanner a chance to monitor correctly.
In some cases, using a paper clip as an antenna is so ‘bad’ that the weaker signals are not strong enough for the scanner to use them. That may allow you to successfully monitor the site. Of course, the down side is that while it might improve your reception on the simulcast, you will lose too much signal strength to monitor weaker, more distant, sites that are not simulcast.
tvengr
Well Known Member
Baltimore County, MD
This is the system im trying to monitor on my 325p2. Nearest tower looks to be 22 miles from me. Says finding control channel. Other devices work on this system. Programmed using freescan software trunking import feature. What am i doing wrong?
Please attach your FreeSCAN programming file so we can take a look at it. You will need to zip the file to be able to attach it. Click on Attach files and open the zipped file. It would help to know your city and the sites you wish to scan.
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
